Got my HEI relay today, how to wire up?
Like he said..
You can use the wire you were previously using (the one on the driver fender well I assume) that had the lower voltage as the trigger (to contact #85 or 86 depending on which one you use for ground).
Make sure these are good, soldered, water tight connections. You entire ignition system will depend on this relay working right and holding up..
I have the same relay; did you get the pigtail connector for it as well?
The only issue I had with the pigtail is that the wire was smaller gauge than I wanted to use; I ended up not using it and made my own connector
Relay Basics
A relay is made up of three parts:
- Coil: There has to be an electrical coil that creates a magnetic force when powered. In a Bosch-style relay, which yours is, the connections to the coil are 85 and 86.
- Armature: The armature goes through the coil and is held in the off position by a spring, and moves to the on position via the magnetic force of the coil - when it is engergized.
- Contacts: Relays are shown in the "off" position and the common connection (terminal 30 in this case) is connected to terminal 87a. But, when the coil is powered then terminal 30 is connected to terminal 87. In other words, the little arm is pulled down toward the coil.
ola1234
05-01-2022 02:08 PM
SilverBullet131313
01-30-2006 10:28 PM
