1997 Ranger/Mazda 2.3L p0340 misfire problem - Ford Truck Enthusiasts Forums
Old 04-03-2014, 10:46 PM
mtdyi mtdyi is offline
mtdyi is starting off with a positive reputation.
I cannot figure out what the problem is on my '97 2.3L. I threw a p0340 code last week and the truck started misfiring while idling and driving (especially 2500 rpm and beyond). I have 93,000 miles on the truck and decided it was time to replace the timing belt while I replaced the camshaft positioning sensor. A local shop checked the signal from the CPS and it was good as well as the wiring. The alternator is not throwing any A/C current either (the CPS is magnetic). Does anyone know more about this problem? I have read about every thread about this.
Additionally replaced:
Spark Plugs
Battery
Does anyone know if the PCM can give the wrong code? I am about to replace my PCM with a remanufacured one but from what I have read, this usually is not the problem.
Is it possible my ICM and crankshaft position sensor are not communicating to fire the spark plugs?
Help needed Jonathan Day 2004 - 2008 F150 8 10-03-2016 04:06 PM
P0135, P0141, P0155 & P0161 =HO2 Sensor Heater Circuit TheDoveNestVansion 3.8 & 4.2L V6 3 05-15-2016 03:57 PM
P0344 and P0340 with some helpful information about camshaft position sensors NM3 2004 - 2008 F150 2 01-19-2016 05:52 AM
98 ranger--- camshaft position sensor 82fordguy Ranger & B-Series 5 07-25-2009 12:16 PM
Help with codes P0340 & P1316 asp84 1999 - 2003 7.3L Power Stroke Diesel 8 12-11-2008 02:00 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
