Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-03-2003, 03:29 PM
jdurrant jdurrant is offline
Garage is empty, add now
jdurrant is starting off with a positive reputation.
Vapour Locking
Todays question isn't about a truck, but I am sure most of us FT fans also have a Ford Car, so I am hoping that someone else may have an answer to this. I just bought a 2000 Contour used, as is. it runs fine till it warms up, then it starts to cut out, like it is vapor locking. the hotter out it is, the worse it gets. If I sit in cruise control at 55, on a flat section of road, it isn't really noticed, but if I need to climb or go much faster it gets real bad. Is there a sensor or something that might be causing this. ANybody have any suggestions?
  #2 (permalink)
Old 07-03-2003, 03:32 PM
Vapour Locking
Also, the longer I drive the worse it gets, after about an hour at freeway speeds it sputters out completely and dies. (Weak fuel pump not keeping up maybe??? Computer problem?)
  #3 (permalink)
Old 07-11-2003, 02:18 PM
timcarlquist timcarlquist is offline
timcarlquist is starting off with a positive reputation.
Question Vapour Locking
I'm having the exact same issue with my 1985 Ranger with 2.3L engine. I've changed all the usual suspects except the fuel pump. Any help on this would be appreciated. I don't know if you heard something offline (if so, please share) otherwise I'm sure you could use this info as well.
Help!!!
  #4 (permalink)
Old 07-12-2003, 06:31 PM
Vapour Locking
OK here is what I have so far. The dealer is taking responsibility for it so I won't have to pay. They are saying that the fuel flow is about half of what it is supposed to be. They tried a filter and that didn't fix it. they are currently putting in a new fuel pump... We will have to see what happens that way.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
