Emissions hoses-The colored 1/8" plastic stuff?
Hello--
Well, as the major tune up ensues, some issues have arisen....
The small diameter emissions hoses, about 1/8" in diam, are brittle and disintegrating in my hands!
The sticker under the hood shows four different colors connecting various parts. The colors are white, black, red, pink, and a short green piece. Each section connects to the part with a rubber connector (most appear to be L shaped).
Where can I get this colored emissions plastic hose? I want to keep the colors the same.
I tried Rock Auto and they don't have them.
Thanks
Thanks
Nice! Those should last for eternity! After seeing your brake line idea, I started thinking.....what about that new plastic brake line? I believe it too is 3/16". Is brake line 3/16" ID or OD?
What size are the OEM colored plastic lines?
I could even paint the plastic lines with paint suitable for plastic. Much easier to work on and flex, although not as durable as metal.
on
1 Post
I had a similar issue with my truck recently. I just went the easy route with black rubber vacuum line I bought in bulk from the parts store. After it was routed, trimmed up and zip-tied, it looked just fine, and functioned well. Just a quicker, easier option to the rigid lines.
Cheers,
JD
Cheers,
JD
on
1 Post
Cheers,
JD
Cheers,
JD
Cheers!
JD
Cheers,
JD
Cheers,
JD
52F1Gary
01-25-2015 08:02 PM
460 FORD MAN
13
09-14-2012 01:05 AM
MikeS29
18
06-24-2012 02:12 AM
