3.2L Power Stroke The 5 cylinder 3.2 Power Stroke engine fitted to the 2014+ Ford Transit, and new Ford Ranger. Called the 3.2L Duratorq TDCi
2015 3.2L Transit to 2002 Ranger engine swap
Old 04-03-2014, 08:54 AM
DemonRace6's Avatar
DemonRace6
DemonRace6 is offline
Hi!
I have often looked into putting a diesel engine in my 2002 Ranger. It has been done with the Cummins 4bt and Kubota engines, there is even a place in Texas that will drop a 3.0L TDCi in for $22k
Diesel Toys - Ranger Swap
The 4bt knocks and shakes more than my 2001 7.3L F250 did.
There are not many parts and not a lot of information or help for a 3.0L TDCi in the USA.
The Kubota engines do not have enough power for me to justify the swap.
With the 2015 Transit coming out this summer powered by a 3.2L TDCi it seems to me the best engine to swap into a Ranger.
Ford Transit 3.2L Duratorq TDCi Power Stroke
And here
What do you think?
This is obviously a long way off for me, but if it is a good idea, I just might do it. And if I do a complete rebuild on my Ranger while doing the swap I could justify spending the money as to have a new car, again. I have lots of reasons for wanting to do this, but I will not get into that now.
Old 04-17-2014, 10:49 PM
damarble's Avatar
damarble
damarble is offline
I think getting one of those to run outside of the donor vehicle will be a challenge. You're probably going to have transfer every sensor, module, and strand of wire to get it to run. Probably have to use the Transit gauges too.
If you get a complete donor Transit it can be done but how many thousands will that be, even for a wrecked one?
Old 04-23-2014, 10:27 AM
parkland's Avatar
parkland
parkland is offline
Cummins 3.3 ?
Turn the power up on a kubota?
Isuzu diesel engines are also nice.
Stay away from the newer computerized engines, it will be a nightmare to make everything work again.
Old 04-23-2014, 10:47 AM
damarble's Avatar
damarble
damarble is offline
Not to mention more expensive to get running. You need all the donor wiring and computers. I really want a Isuzu 4HK1 (5.2L) in my F250 and the engine itself is not outrageously expensive ($3-5k) but I need the whole NPR to be sure I get every little thing required to make it run, and those are still going for $15k or more. A 6BT makes more sense then, I'm just not ready to jump on the Cummins browagon.
For a Ranger sized vehicle there just aren't a lot of mechanical injection diesel options to choose from in the US with a huge void between the 2.0L and 4.0L classes. There's the MB 3.0L but I'm not a huge fan. The Cummins 3.3 is a decent choice but hard to find and very expensive.
If I were building a little mileage monster pickup I'd find a 2WD 5spd Ranger and put in the VW 1.9L with a Toyota trans (adapters already out there). That should knock down 40+ mpg. A friend of mine has one in a lifted 4x4 4Runner but he's done a lot of engine work and expects about 200hp out of it. How long will it last at double the original power levels?
Old 04-23-2014, 11:50 AM
parkland's Avatar
parkland
parkland is offline
Dt 360-
A little info on it:
Cummins Swappers
And if you search around, a few swaps have been done.
Old 04-23-2014, 12:21 PM
damarble's Avatar
damarble
damarble is offline
Dt 360-
International dt360 in f250 pickup - YouTube
Cummins Swappers
He needs to do a lot more tuning. Too much smoke for my tastes.
The DT360 is one I'm interested in but I'm having a hard time find any of those either. Every time I pop the hood on a IH/Ford MD truck around here it's a DT466. That one is way too big for my truck.
Old 04-23-2014, 07:50 PM
parkland's Avatar
parkland
parkland is offline
The 360's have a mechanical pump, so tinkering with that, and turbo selection, you could have a clean running engine, or a smoke pumping behemoth.
There are lots and lots of dt360's around, and cheap. Probably the most under rated diesel engine ever.
Old 05-17-2014, 03:01 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Isuzu 4BD is an excellent engine. Easier to buy a donor delivery truck, source the engine and accessories and then sell off the truck for scrap.
Adapters are available to mate the engine to nearly any trans, manual or automatic.
Josh
Old 06-07-2014, 05:53 PM
Frdtrkrul's Avatar
Frdtrkrul
Frdtrkrul is offline
Look for an old Ranger with the Isuzu 2.2L "Pup". Came out in the 1980s. Very doggy but will get 30s+ all day long. There's one guy that I've followed who dropped in the 4.5L VT265 V6 PowerStroke into a Ranger. Essentially its the 6.0 Leaker but 2 cylinders missing and has 2 turbos in a 6.4L setup. Over complicated though for electronics, but parts are mostly avalible since most 6L parts will work in it.
Old 06-07-2014, 06:23 PM
Bullitt390's Avatar
Bullitt390
The 83/84 Ranger Diesel was a Mazda/Perkins 2.2l 4 cylinder.
The 85-87 Ranger Diesel was a 2.3l 4 cylinder Mitsubishi.
Josh
Old 06-08-2014, 01:46 PM
damarble's Avatar
damarble
damarble is offline
Yeah the little Isuzu came in the Chevys, not Rangers.
Post-Chevy days
1983 - 2012 Ranger & B-Series
12-08-2014 07:06 PM
Mustang Gregg
11-04-2011 06:17 AM
wendal
08-01-2008 11:07 AM
COUGARFIED
08-29-2006 08:41 PM
jman724
General Diesel Discussion
05-21-2006 01:27 PM
Quick Reply: 2015 3.2L Transit to 2002 Ranger engine swap
