oil pressure and coolant temp sensor mounting - Ford Truck Enthusiasts Forums
Old 04-03-2014, 08:09 AM
86scotty's Avatar
86scotty 86scotty is offline
86scotty is starting off with a positive reputation.
I posted this in the van forums but no response in a week.
I have a 95 E350 with a 7.5 (460). I bought a pillar pod and some extra guages, but want to keep the OEM dummy gauges in the dash working too.
I have a triple pod and trans temp, oil pressure, and water temp.
trans temp is figured out and will be wired tomorrow, no problem there.
Where can I tap in for coolant temp if I want to keep the stock sensor working too? The guage I bought has a 8 or so feet of sensor coil and a screw in sensor with different fittings. I'm not even sure if it will reach to the block easily or if I can add to it, but where can I tap in?
Also, I looked up where the factory oil pressure sensor should be (under the front of the block near the oil filter) but I cannot find mine there. I have not removed the oil filter or any coolant hoses and don't want to have to. I can T off this sensor for my oil pressure guage once I find it, if I understand this correctly.
Thanks
Old 04-03-2014, 06:00 PM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
Quote:
Originally Posted by 86scotty View Post
........Also, I looked up where the factory oil pressure sensor should be (under the front of the block near the oil filter) but I cannot find mine there.........
The early 460 had the oil pressure sender/switch located up on the top of the block, facing up, way at the rear, to the passenger side of the centerline. Just behind the sender the block would slope down to the trans bell housing.
Any chance that is still the location?
Old 04-03-2014, 10:38 PM
86scotty's Avatar
I'll have to pull the doghouse and look I guess, but I with I knew exactly what I was looking for. I know what a sender should look like in general but not completely sure what this one will look like.
Old 04-03-2014, 11:55 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
I put a pipe tee in for the temp senders but I thing moving the senders out of the "stream" of coolant in the intake made for a cooler reading on both the factory and the aftermarket gauge. I installed a short hose to move the oil pressure sender out to a location easier to install a tee in it. Put the oem sender in one side and the aftermarket in the other and it works fine.
Still working on a solution for the temp sender!
Old 04-04-2014, 07:16 AM
86scotty's Avatar
Thanks, but where is your oil pressure sender?
Old 04-04-2014, 09:30 PM
eakermeld's Avatar
Back of the engine, up top sort of on passenger side. A real bear to get to!
Old 04-05-2014, 11:12 AM
86scotty's Avatar
Not on a van! Perhaps the ONLY easy thing to get to on this thing!
Old 04-06-2014, 12:17 PM
eakermeld's Avatar
Oh thats right! You have a dog house you can remove to get to it. Lucky rascal!
Old 05-18-2014, 09:51 PM
kountzecobra kountzecobra is offline
kountzecobra is starting off with a positive reputation.
Did you come up with any idea on where to locate the temp sender?
Old 05-18-2014, 10:14 PM
eakermeld's Avatar
Quote:
Come over here and check this out. It seems to be working better every day.
http://www.ford-trucks.com/forums/13...em-gauges.html
Here is another good idea.
http://www.ford-trucks.com/forums/13...-on-460-a.html
Old 05-19-2014, 10:51 AM
Thanks for the links. I think I will screw a 3/8" tee into the gauge sender location and add the new gauge sender and see how that goes. If the factory gauge reads as it did before (whatever that's worth) It should mean that the location is OK.
[DONE] Custom Guage Install, 5.4 3v, 4R75E (Oil Pressure Guage and Transmission Temp) Matt Howell 2004 - 2008 F150 4 06-30-2014 05:53 PM
coolant and oil pressure sensor mounting locations 86scotty 1968-2013 Full Size Vans 3 05-18-2014 10:05 PM
aftermarket triple gauge questions wickedklown83 1987 - 1996 F150 & Larger F-Series Trucks 8 04-18-2010 02:09 PM
Aftermarket Mechanical Gauge Installation Pele Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 08-25-2007 09:27 PM
New Gauges Installed - Oil Pressure, Oil Temp, & Water Temp jtharvey 1999 - 2003 7.3L Power Stroke Diesel 16 11-14-2006 01:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
