Thinking of replacing steering stabalizer
Old 04-02-2014, 09:38 PM
Iaff113's Avatar
Iaff113
Iaff113 is offline
How many have replaced it? Has it made a huge difference. If I do it I'm going to order the rancho RS5413.
Old 04-02-2014, 09:56 PM
Rick.charters's Avatar
Rick.charters
Rick.charters is offline
I am going to replace mine with a dual set up. It's supposed to be better on your ball joints and steering while towing.
Old 04-03-2014, 05:53 PM
Iaff113's Avatar
Iaff113
Iaff113 is offline
We'll the 5413 should be here tomorrow. Not sure what it will change. Just wanted to change it since I just put in all new 9000'S. I looked at the duel set up but didn't want to spend that much, and I didn't have any wobble or a lot of play.
Old 04-03-2014, 07:35 PM
Rick.charters
If you got wobble or play you are driving a Dodge and a stabilizer won't help you!! Lol
Old 04-03-2014, 07:36 PM
xaviar's Avatar
xaviar
xaviar is offline
I changed mine last year with the bilstein single from XDP. I wish I'd bought the dual setup instead. Noticeable difference.
Old 04-03-2014, 11:22 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
I went from stock, to BDS dual, to nothing, to a single Bilstein 5100 in the stock location. 34" heavy Nitto Trail Grapplers, had a 2" leveling kit for awhile. I honestly didn't notice a huge difference between any of them during normal driving, but the duals were stiffer on really bad roads. The single works fine now, but I blew out the passenger side inner tie rod end boot, not sure if that's just bad luck and 8 year old rubber or because I ran without any stabilizer for a solid 15k miles.
(hit a stump with the center bracket on the duals, bent it down to where it contacted the tie rod. pulled it and didn't notice a huge difference when the truck was a DD)
Old 04-03-2014, 11:49 PM
Snuggyworm's Avatar
Snuggyworm
Snuggyworm is offline
bryan,
i have the bilstein 5100 setup all around. she runs fine. i just need to replace the rear sway bar cos of a wreck last year. she drives fine but i'm thinking of doing a bunch of things for peace of mind.
ope u resolved ur tie rod end prob. yikes. i've already replaced everything related to front end except the trac bar and the driver side sway bar end link. when i say almost everything, i meant it. lol.
Old 04-04-2014, 05:01 AM
xaviar's Avatar
xaviar
xaviar is offline
Originally Posted by Snuggyworm
bryan,
How many miles do you have on your truck. I had 5100's on my dually and liked them. Thinking of putting the 4600's on my SRW LB.
Old 04-04-2014, 10:02 AM
Snuggyworm's Avatar
Snuggyworm
I put them on at about a little over 100k miles. It's now 144k miles. She's still going. Lol.
Dom
Sent from my iPhone using IB AutoGroup
springdale6
04-01-2018 09:26 PM
A/Ox4
1999 to 2016 Super Duty
06-06-2014 11:51 PM
Sickler1
08-14-2011 12:36 PM
StanleyZ
12-08-2008 09:30 AM
f350rebel
02-28-2008 10:38 PM
Quick Reply: Thinking of replacing steering stabalizer
