Left-Rear power door lock mechanism - How to remove?
Old 04-02-2014, 03:36 PM
SoCalAngler's Avatar
SoCalAngler
SoCalAngler is offline
Hello-
My driver's side rear door lock is not locking/unlocking like it should. It moves very slowly and will lock, nut not unlock. I removed the door panel.
I can't figure out how to remove the parts to inspect and attempt a repair. It looks like the door lock is actuated by the latch mechanism that bolts to the side of the door (door jamb). I removed the flexible rod that connects latch to door lock ****, but can't figure how to remove the rod that connects the exterior handle with the latch. Th rod has a s shape end to it and you would need to twist the latch around to remove the rod.
Thanks!
Old 04-02-2014, 03:49 PM
Truck Guy99's Avatar
Truck Guy99
Truck Guy99 is offline
I have the same problem with my rear crew door locks. Subscribed
Old 04-02-2014, 04:29 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
You need to drill or grind off the head of the rivet that holds it to the door. You will also need a 1/4 rivet to put it back on(and the BIG 1/4" rivet gun)
Old 04-02-2014, 08:15 PM
SoCalAngler
can a bolt/nut be used in lieu of rivet?
Old 04-02-2014, 08:49 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
You can use a bolt. I did when I put the rear door actuator back in my '97 Crew Cab. But it wasn't easy to get at the head of the bolt buried behind the actuator. I might end up regretting I did it that way if I can't get a good enough hold of it to get it removed when it comes to that.
Old 04-03-2014, 04:50 AM
Diesel_Brad
And that is why I use the 1/4" rivet
Old 04-03-2014, 10:04 AM
SoCalAngler
I don't want to have to buy a 1/4" rivet gun, so my options are limited!
Old 04-04-2014, 04:19 AM
Diesel_Brad
Good luck. I tried a bolt but could not get to the inside to hold it
Justa FYI, that rear actuator is $300
Old 04-04-2014, 12:04 PM
Nothing Special
There have been a few threads recently about subbing in other actuators that aren't ridiculously priced. Here's one. https://www.ford-trucks.com/forums/1...actuators.html I haven't tried it myself yet, but I might. The actuator I bolted in works but it squeals obnoxiously. Not bad enough to pay $300 to replace, but I might give it a shot sometime.
Old 04-04-2014, 06:02 PM
SoCalAngler
Bob, thanks for the link. Just what I was looking for! I asked OP for the part # and brand name. I found a Dorman part # 746-147 that looks just like the one in pic. This part # is for a 1991 Country Squire (last year of this wagon). $27.89 at Rock Auto.
Old 03-24-2020, 10:28 AM
Jeremy Balderrama's Avatar
Jeremy Balderrama
Jeremy Balderrama is offline
Does anyone know if these actuators will work with a f250 as well?
Clem's Cousin
06-08-2016 09:02 PM
powerstroker100
1999 to 2016 Super Duty
12-18-2013 03:48 AM
kamloops
1997 - 2003 F150
04-19-2008 01:04 PM
blueovalboy86
1978 - 1996 Big Bronco
06-10-2007 05:42 PM
97ExplorerEddieBauer
10-06-2004 12:55 AM
Quick Reply: Left-Rear power door lock mechanism - How to remove?
