Holley 4BBL on a 64 292??
PO of this truck was kind enough to provide some good records. At some point, the 292 was rebuilt, bored .060 over, crank .010 under, allegedly installed large valve heads, stock 4BBL intake, but it has a Holley 4 barrel on it. Which I know at least needs rebuilding but also think maybe to much CFM. What did Ford use for a stock 4 barrel carb back then?
C3TZ-9510-A .. Holley 4V Carburetor (Motorcraft CA-241-A) / 1963/64 292 / Obsolete
The problem with FoMoCo parts catalogs: There is no Holley number listed.
the holley site has a wizard for you to walk through that will give you the correct carb. try that.
Holley Interactive Carburetor Selector
twise
09-02-2008 10:03 PM
