5W20 or 5W30 and Filter ? for 6.2L - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 04-02-2014, 06:55 AM
RRRAVEN RRRAVEN is offline
RRRAVEN is starting off with a positive reputation.
Hi Everyone-
The owners manual for my 2014 F350 6.2L V8 gasser calls for 5W30 oil and the filler cap is labeled 5W20 oil. The dealer pulled my VIN and Ford says 5W20 oil. I guess it must just be a mistake/typo in the owners manual? Anyone have any insight into this? What is the correct weight for sure?
The manual also calls for a Motorcraft FL-820S oil filter. This is my first oil change for this truck and the original oil filter that I just pulled off has no identification numbers and looks to be made by a different manufacturer as it is not made the same as the Motorcraft FL-820S that I just bought. Why the difference?
Thanks in advance for any feedback.
RRRAVEN
Old 04-02-2014, 07:15 AM
FordmanNJ's Avatar
FordmanNJ FordmanNJ is offline
FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.FordmanNJ has a great reputation on FTE.
Motorcraft Syn Blend 5W20 for the oil. Motorcraft FL-820S for the filter. Local Walmart generally has it in stock. Remember you will need a total of 7 Quarts of oil. Check Groupon or see of the dealership has a oil change special. Many times these deals workout to be even or cheaper in cost then you doing it yourself. My local Ford dealer is usually 25 bucks for my truck which is the cost of the filter and oil. It's a toss up for me at least.
Good luck.
Old 04-02-2014, 01:31 PM
moosesp moosesp is offline
moosesp is starting off with a positive reputation.
I had the same question for my service manager. He indicated that it is in fact 5W20 that is required and that the manual is incorrect for the 6.2 liter gas motor. Also of note, if you are located in Canada then the Motorcraft 5W20 oil is not a semi-synthetic oil but a mineral based oil. I have been told this by 2 different dealers up here. If someone has any different info on this please feel free to chime in.
Old 04-02-2014, 03:10 PM
t_b's Avatar
t_b t_b is offline
t_b is starting off with a positive reputation.
Quote:
The Motorcraft 5W-20 synthetic blend oil we have here in the U.S. is a Group III oil, which is mineral based - fractionally distilled and hydrocracked petroleum.
If I were in the Great White North I would use the Canadian Motorcraft oil and not lose a moment's sleep about it - if it meets Ford's specs then it meets Ford's specs.
Old 04-02-2014, 05:02 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
this has been discussed before. If you go to the Ford website you can download an updated copy of your owners manual with the corrections in it.
5W-20 is correct.
Old 04-02-2014, 07:10 PM
Thanks for all the feedback! It's amazing, my manual was printed in late 2013 and it still has the misprint. Just wanted to verify the proper viscosity just to cover all the bases if a engine warranty issue comes up. Good to go!
Old 04-03-2014, 03:43 AM
ATP Pilot's Avatar
the 2nd printing has an error, corrected in 3rd printing
https://owner.ford.com/servlet/Conte...OwnerGuidePage
Old 04-05-2014, 08:20 AM
Dave HM Dave HM is offline
Dave HM is starting off with a positive reputation.
I am with the NJFordman. My local dealer charges 19.95 for the oil and filter on my F250.
His sign says come one come all.
I took the wife's toyota in there the other day for 19.95.
Do the 2016 F-250's still use the FL-820-S oil filter? Tawn 6.2L V8 2 05-06-2016 02:28 PM
Larger Oil Filter Fleetsuper 1999 to 2016 Super Duty 19 06-15-2014 06:44 PM
No oil pressure after oil change RobbyMartin 1997 - 2003 F150 30 10-02-2010 06:35 AM
What are the differences in FL820S and the FL-1-A ? PartsKen Oil & Lubrication 3 09-26-2009 02:08 PM
Difference Between Motorcraft 820 and 820S Oil Filters Beast12 Oil & Lubrication 4 07-24-2005 04:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
