Mirrors on 52 F1 door hinge - Ford Truck Enthusiasts Forums
Old 04-01-2014, 11:18 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
I have searched with no luck finding an answer. I am trying to put my doors back on with the curved arm mirrors that are supposed to fit. I did find that on '51 and '52 the hinge needs to be slightly ground down. The mirror mount is too shallow to line up with the holes on the hinge unless it is out in front where the set screws would have nothing to set on. I ground one of my hinges down as far as I dare to and it still won't quite fit. I can't see any way to get these mirrors to work. Anybody else have the same problem? Any solutions? I wonder if the other mirrors available have the same problem.
Old 04-02-2014, 06:04 PM
topmoo's Avatar
Ok, just overly cautious. All the replies got me motivated to do some more grinding. Got it to fit.
Old 04-02-2014, 06:27 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Haven't heard of that issue before. Whose mirrors are they? Hope you remember not to pound the pin thru without support under the bottom part of the mirror bracket?!
Old 04-02-2014, 07:06 PM
rhopper's Avatar
rhopper rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
On my 48, I had to grind the mirrors. It was in the area of the set screw, had to curve it a little.
Old 04-02-2014, 08:56 PM
topmoo's Avatar
Quote:
Yes, they went in great with a hardwood block below. I had to grind off about 1/16"+ of the curve on the hinge so that the holes would line up. Also had to grind off the casting line on the back of surface of the mirror mount and a little more - like rhopper. These came from Dennis Carpenter from Taiwan. At first I was afraid that I might grind through the hinge, hard to tell just how thick it was. I got online and read from several sites that the 51-52 had fatter hinges and they needed a little grinding. More than a little... but got it to fit. Now on to the passenger side.
Old 04-04-2014, 06:54 PM
topmoo's Avatar
This is how much I had to grind off on the passenger side.
Stick Mirrors 1999 F-350 for parts Makwagon Ford Truck Parts for Sale 0 09-26-2016 07:52 PM
53-56 hood hinges? vanspeed 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 09-15-2016 08:43 PM
Driver Door "Thumpin" Over Rough Road. Hidden Cracks in Cab? Scotty's 52 F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 05-02-2016 02:17 AM
Outside Mirror Opinions Needed Scotty's 52 F3 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 01-05-2016 11:23 AM
Hinge pin replacement 93 F250 pjckm 1987 - 1996 F150 & Larger F-Series Trucks 1 08-17-2006 10:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
