Y-Block Dampner Timing Marks
They tend to be pretty faint. Should be a long line marked 0* TDC and the other marks shorter, indicating degrees BTDC, etc.
In case anybody doesn't know, the originals because of their age have problems by now because the rubber bonding deteriorates and the outer ring will slip off its index, so the marks are pretty much useless anyway when you do find them, and won't do much for vibration damping either.
This bond can also fail altogether and do real nasty stuff - like launch through the radiator at highway speed . Not good.
Sent from my iPhone using IB AutoGroup
Thanks Ted, I found them. I was given a tip on another forum where to find them. If you draw a straight line thru the center of the dampner and line it up square with the key slot, then go about 108 degrees to the right, that will get you close. I hear what your saying on old dampners. Is there a place in the US to have them rebuilt? The stock dampner I removed has slipped. I marked it before removal and it is just a bit left of the line instead of 108 degrees to the right. The donar is old and used to, but the rubber is showing some wear and tear.
Not all dampners are marked the same. Some are on the pulley, some are on the balancer. Some are just a "v" groove, or a high spot. These dampeners are old and the rubber is most likely deteriorating. I believe the good news is if they come loose, they dont go thru the radiator and down the highway at rocket launch speed. They go towards the timing chain cover but stay on. At least thats what I have been told.
There used to be the damper doctor, not sure if they are still around?
The cost, plus shipping both ways is still probably cheaper than buying new, though? Didn't want my truck to be down that long so bit the bullet and bought a new manufacture damper off of eBay, I think it's through Mummert's or at least the same folks who supplies them. Quality part. The old one on mine was trashed, slipped, and had a wobble. Scary! Engine is happier now for sure, too.
Yeah, looks like http://www.damperdoctor.com is alive and well so that's an option. They sell new ones or, will reman your unit and send it back to ya.
A vacuum gauge works slick for setting timing, also for setting idle mixture, so you can just hang the timing light on the wall for decoration. Maybe the performance guys need them, folks who study advance curves and swap out distributor springs, I dunno.
