Dad's Frame & Suspension
In cleaning up the frame today I ran across a "thing" that I cannot ID. I've looked in the master parts catalog - to no avail. It is shown circled in yellow in the first picture below, and then in two closer shots.
It is where the #1 crossmember meets the frame and the inside reinforcement. And, it is loose! The one on the passenger's side is a true rivet, but this one is odd. I'm concerned that it is supposed to be a rivet and needs to be tight, so I'd really like to know if any of you have something similar or a true rivet. Since the engine is going to be bit stronger I'm thinking I need to cut that one off and install a G8 bolt.
She's a Huck bolt Gary, standard aviation fare.
Similar to a rivet, they are pulled up tight and the collar is swaged until the core bolt yields.
They should be tight, if they have worked loose they are no longer doing their job. The factory would have used them where it was easier and faster then a solid rivet or bolt due to head side access.
To remove it, just split the collar off with a cold chisel and punch it out.
A fresh grade 8 bolt with a light interference fit on the shoulder would replace it nicely
Na, it's just a small gap between the frame rails, for whatever reason they stopped the weld about half an inch from the end. Possibly they designed it to flex around this area of the junction and that's why it's not welded up as tight as it could all be.
Thanks, Brad. If by "shoulder" you mean an unthreaded portion the I understand. But I'm not sure I can find a G8 with that short of a shoulder, although I could run the threads down further on one with a longer shoulder. Anyway, looks like I'll be pulling that out and replacing it.
If there's no shoulder, then it's a machine screw, but you probably knew that
But where's the fun in that
