1950 overflow tank install
Old 04-01-2014, 02:27 PM
1950F2's Avatar
1950F2
1950F2 is offline
Does anyone have pics of an install of those aluminum overflow tanks for a 239 flat head in a 1950 truck??
Do you really need one or is it more of a look thing??
Will be running new water pumps, thermostats, rad flushed out. new rebuild on motor too.
Thanks for any input on the subject.
Old 04-01-2014, 04:24 PM
delawarebill's Avatar
delawarebill
delawarebill is offline
overflow
i have the same set up as u and i do not have a overflow. has not leaked any pressure from rad so far. just use tubing down the side.
Old 04-01-2014, 04:50 PM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
I've never had one on either of my f1's here in AZ... Never had a problem needing a overflow tank. My first f1 had a I6 and then a 425ci Rocket motor in it ran great... My Current f1 has a 350ci and still no problem here in AZ.
Old 04-02-2014, 09:06 AM
1950F2's Avatar
1950F2
1950F2 is offline
Thanks for response.
I guess I'll leave it alone and keep the stock set up.
Old 04-02-2014, 07:35 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,838 Likes on 1,837 Posts
The advantage to an overflow tank is that when/if you ever have a flow over it will go into the tank, then as the truck cools it will pull the fluid back into the radiator.
You don't necessarily need one (unless you are going to the dragstrip). For the older systems they typically didn't fill the radiator tanks all the way to the top so that there was some room for expansion as the coolant got hot.
Bobby
Old 04-02-2014, 08:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
The other advantage is that there is no air in the system, hot or cold. Helps with corrosion and additive life. For a stock flathead V8, with 22 qt system, you need an overflow tank that holds almost 2 qts tho.
Old 04-04-2014, 05:40 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
Bobby and Ross are right. I installed a long, thin, SS tank from Speedway on my '50 as you can see from the picture below. It is enough to keep the system full but as Ross says if you were going to run it hard or tow it may need something larger. I installed it because it fit, looked good and did the job for my type of driving, cruising.
lm987
02-24-2014 01:09 PM
St33mF3
16
12-18-2012 06:57 PM
TestDepth
11-14-2007 05:49 PM
mjacobbe
05-06-2005 04:38 PM
Quick Reply: 1950 overflow tank install
