Idaho's April 2014 BS Spot
#62
Hi Everyone. I've been studying in the BSU library and working on my English 102 "Unit 3 Final" website for several hours now. I have a little over half-an-hour before my math class. I think it's time to get up, go outside in the sunshine, and take a walk before class begins.
I have a friend coming over on Sunday to help me fix the brakes on my truck.
#63
#64
Good morning. What are your plans for today? I will be doing the "prep-work" on my brake system. Gonna try to knock off the slight edge built up in the drums and clean out the brake dust. I might try to start the disassembly process, too, but we'll see how my back holds up after working on the drums.
I found my o-ring kit. Maybe I have an o-ring that will fit in the leaking A/C line connection. I'd love to get the A/C system vacuumed and recharged before summer arrives. Since we're doing a lot more towing lately, I think I'm going to reinstall my cooling system fan and shroud after I RTV the T-Stat housing connection. It's been slightly leaking since I installed the new water pump last summer. I don't want my gals driving the truck and have it overheat on them when I'm not around.
#65
#70
Sure did rob..the wings on the rotor snapped off and then the whole copper wire on the rotor fell off and was jn the bottom of the distributor. It was a brand new rotor too.
Oh well I went ahead and did some preventative maintenance on it. I replaced the distributor because the bearings in it were wearing out. The fan clutch was going bad. I replacef the water pump since it was right there. A new thermostat as well.. now she is running like a top
Sent from my SM-G730V using IB AutoGroup
#72
#73
