Name that engine and fuel pump!
It does have a second fuel filter between the pump and the carb. So the 65 to 72 240 pump at Truck and Car Shop should work? (page 147)
http://issuu.com/truckandcarshop/doc..._truck_web_cat
I was the first member to give you the info and this was two days ago. First time you asked, you said it was a V6, then you said in another post it was the original I-6.
But it isn't a V6 or the original I-6, because I told you that the I-6's used 1952/64 have the intake & exhaust manifolds on the left (drivers) side.
I said it was either a 240 or 300 I-6 because the intake & exhaust manifolds are on the right (passenger) side.
I also told you it's either from a 1965/66 F100/250, 1974/79 F100/350 or 1980 and later 300 because it uses an accelerator cable.
I posted 2 parts catalog pics of the engine showing the accelerator cable and the bracket that retains it to the head.
I also told you how to ID the cable and to look for the engine's casting date code on the block.
According to the 1964/72 Ford truck parts catalog, the C4AZ-9365-B cartridge fuel filter that fits inside the C3AZ-9355-A canister that threads onto the pump was factory installed in 1965/72 F100/700's 240/300's.
The same set up was also used in multiple other 1964/72 I-6 & V8 Passenger Cars/Trucks, Bronco's and Econolines.
Ditto 1973/76 F100/350 360/390 & 1973/78 500 series and larger trucks with FT engines.
You can buy this pump from any auto parts store, so you won't have to drive to Batavia Street in Orange and buy it from Truck&Car.
Where do you think Truck&Car bought it from? A local auto parts store!
Why the attitude?
Two days ago I posted in the forum that was appropriate for my 1960 truck. You advised me that the engine wasn't original and could possibly be from the sixties or even 70's....or even later...and was a 240/300.....so I posted a second time here....in a forum that might be more appropriate for my engine.
https://www.ford-trucks.com/forums/1...tion-help.html
The main reason for the post here is to identify the fuel pump......and if anyone recognizes the specifics of what the engine is then that would also be helpful.
So two different posts in two different forum years.
Why the attitude? Your help is appreciated, but criticism of me posting twice with similar but different questions is ridiculous.
Why the attitude? Because you are asking the same fracatta questions that not only I, but other members gave you the answers to...TWO DAYS AGO!
Ridiculous!
This fuel pump wheeze is the only thing that's a new question.
Now, who do you suppose will be able to ID the accelerator cable and give you the part number for it, locate one, since all are obsolete?
The only member I'm aware of has an attitude. 'Course by the time you get around to posting the info, I'll probably help you.
Ridiculous!
This post has nothing to do with the cable and primarily is an attempt to identify the fuel pump.
And by the way..........Only one "t" in Fracata!!!!! Hmmmmm......not very nice being criticized, is it????
This is the second time you've used this word and the second time you've misspelled it!! Please don't do this again!!!
Urban Dictionary: fracata
Therefore, you will get no further help from me.
raidergeo
01-01-2010 04:26 PM
MudBugn
03-30-2006 11:35 AM
