trouble with one cylinder - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 03-31-2014, 07:36 PM
Sam Menard Sam Menard is offline
Sam Menard is starting off with a positive reputation.
Earlier this winter, the engine light came on upon startup for about a minute. I didn't think much about it because it went out and didn't come back on. Brought the truck in for a service last week and asked them to check the codes. They did a quick scan and found something amiss with cylinder #3. I brought it back today for a more in-depth scan and they told me that they are going to replace the coil and see where things go from there. From what I can understand, there is intermittent firing of the plugs. Nothing really stands out as far as engine noises, but my gas mileage this winter has been brutal. I'll provide updates as things progress.
Sam
Old 04-01-2014, 12:49 PM
BMWBig6's Avatar
BMWBig6 BMWBig6 is offline
BMWBig6 is starting off with a positive reputation.
Misfire with 2 spark plugs per cylinder? Hmmm, please keep us posted.
Old 04-01-2014, 08:56 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
Quote:
There is only one coil for those 2 spark plugs, so yes a single bad coil would cause a misfire
Old 04-12-2014, 09:36 AM
Wel, they replaced the coil. Now they have to replace the catalytic converter. Apparently, the misfires damaged it. Thank goodness for the warranty.
Sam
Front passenger brake smoking Sam Bracken 1987 - 1996 F150 & Larger F-Series Trucks 9 07-07-2016 02:26 AM
Broke Down in Boise! WolfCreek540 6.0L Power Stroke Diesel 36 05-19-2016 05:33 PM
Won't shift into 3rd gear TTsam 1973 - 1979 F-100 & Larger F-Series Trucks 10 03-28-2016 12:59 PM
What do you use your Upfitter switches for? Sam Menard 6.2L V8 20 08-25-2015 02:37 PM
ATF change, delay R shift and only 1-4 gears lablue96 6.0L Power Stroke Diesel 11 03-13-2015 06:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
