Cold start worse after Rev-X!!!! - Ford Truck Enthusiasts Forums
Old 03-31-2014, 08:51 AM
jayc3169's Avatar
jayc3169 jayc3169 is offline
jayc3169 is starting off with a positive reputation.
Well this problem persist! Cold starts have been an issue all winter, Friday night I changed the oil (and filter) and added Rev-X. I'm using Shell Rotella T6 5W 40 Full synthetic like I've used since I've had the truck (Never an issue before). I also changed the Fuel filters as well. My cold start issue is significantly worse (See video below). Throughout the winter I have changed glow plugs, GPCM, one glow plug harness, ICP sensor, cleaned the EGR, and checked the FICM voltage. I don't even know what to do with it now beside take it to Ford and pay the $150 to diagnose. Should I give the Rev-X more time to work? I'm getting codes for cylinders one at a time) balance/contribution. I'll get one, shut the engine off, then back on and get a different one. No other codes though. The problem started right after I changed the oil for the winter and has continued. Any help would be greatly appreciated!
<iframe width="560" height="315" src="//www.youtube.com/embed/V01CLZbiqR0?rel=0" frameborder="0" allowfullscreen></iframe>
Previous post of mine on the matter:
http://www.ford-trucks.com/forums/13...ease-help.html
Old 03-31-2014, 09:23 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Yours being an '03, I'd check and make sure your harness isn't chaffing anywhere.
If I lived closer to you I'd come over and hook up the AE, but that is a seriously rough idle.
What happens if you try to drive the truck?
Old 03-31-2014, 09:24 AM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
The FICM can still have issues even though the voltage is good, do you know anyone with a 6.0 that you could borrow their FICM for a test?
Old 03-31-2014, 10:12 AM
9228.bobcat's Avatar
9228.bobcat 9228.bobcat is offline
9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.9228.bobcat has a great reputation on FTE.
X2 with what mustang said. If its bouncing around like like that I would check your ficm or send it to ed and have him check it for you, check and make sure the plugs are plugged in all the way or chaffing on the ficm wiring harness. Oh and load test each battery
Old 03-31-2014, 03:33 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Sounds/looks more like a leaking injector to me. Are all the codes on the same cylinder bank? Have you done a bubble test?
Old 03-31-2014, 07:28 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Do you monitor the fuel pressure?
If injectors are at 235k miles (approx) like the truck, then it is probably just time for them to start having problems. If not, then you may have issues w/ proper fuel pressure - especially when running your tuner.
Old 03-31-2014, 08:41 PM
jayc3169's Avatar
Different sides but now constantly 0275. Getting hot start issues now as well. Would a high pressure oil leak cause all of my symptoms?
Old 04-01-2014, 05:28 AM
No.
Pull the secondary fuel filter lid and do a bubble test. Takes less than 5 minutes.
Old 04-01-2014, 05:42 AM
jayc3169's Avatar
Just did the bubble test. No bubbles but the fuel bowl overflowed! Is that normal?
Old 04-01-2014, 05:51 AM
If you cranked the engine over with the key yes, you need to crank it over with the starter wire on the passenger side as shown in this video,
Old 04-01-2014, 05:54 AM
jayc3169's Avatar
Ok, I'll try that!
Old 04-01-2014, 06:35 AM
jayc3169's Avatar
Still no bubbles, tried starting it up and it died again. I'm posting a vid, should be up soon.
Old 04-01-2014, 07:50 AM
jayc3169's Avatar
Here's the video.
<iframe width="560" height="315" src="//www.youtube.com/embed/Isek_nj6PkE?rel=0" frameborder="0" allowfullscreen></iframe>
Old 04-01-2014, 09:33 AM
KIDkiser KIDkiser is offline
KIDkiser is starting off with a positive reputation.
One thing that caught my attention,was the oil filter cap,is that an oem?I once saw a 6.0 that done about the same thing,but it wouldn't run as long as yours.
Come to find out it was the cap and filter.
Old 04-01-2014, 04:43 PM
BryanStein BryanStein is offline
BryanStein has a good reputation on FTE.BryanStein has a good reputation on FTE.BryanStein has a good reputation on FTE.
At 59 degrees I don't think its stiction
At 59 degrees, I would not be looking at Stiction as the problem.
Rev-X did the trick for my 6.0 allingeneral 1999 to 2016 Super Duty 12 08-13-2012 10:44 AM
Rev-X advice caiati 6.0L Power Stroke Diesel 13 01-28-2012 07:32 PM
REV-X oil additive rocks for injector stiction problems stroked4life Oil & Lubrication 3 03-06-2011 03:19 PM
my Rev-X experince RollingRock 1999 to 2016 Super Duty 18 02-22-2011 04:37 PM
Pre Rev-X Oil Sample DoneDunIt 6.0L Power Stroke Diesel 6 05-10-2010 08:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
