1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-19-2014, 07:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Lifetime LED Headlights (Review)
Old 10-10-2015, 02:43 PM
acf6's Avatar
acf6
acf6 is offline
I am currently on my third set of these...there has been an improvement on the exterior each time. New sets been good for a few weeks
  #122
Old 10-10-2015, 02:53 PM
2112's Avatar
2112
2112 is offline
Do you know what is killing them?
  #123
Old 10-10-2015, 03:13 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
You know that's a good question. We need Miles to tell us how he
kills a lot of things on his truck. ( snicker )
Mud bath ??
BTW I don't get any RF noise from my HIDs.
Sean
6.0L Tech Folder
  #124
Old 10-10-2015, 03:50 PM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
Damn and i'm still on my same set of HID's i put in back in 2010.
  #125
Old 10-10-2015, 04:15 PM
2112's Avatar
2112
2112 is offline
I have been thru 4 sets of HID's. None of them cheap. Sick of the hassle of melted ballasts, flickering bulbs etc. They are all good for the first year or so. Well, except that the only difference between hi and lo is the aimed height. Same brightness.
  #126
Old 10-10-2015, 09:16 PM
acf6's Avatar
acf6
acf6 is offline
idk, they just kept flickering for like 2 days then would die. only 1 headlight would die. the newest set gets rid of this little voltage regulator box entirely...just headlight and plugs right into harness. i think these will be good for a while
  #127
Old 10-10-2015, 09:25 PM
acf6's Avatar
acf6
acf6 is offline
also in my friends 2015 6.7 he tried LEDs in his fog lights and it severly interfered with the radio...he ended up just returning them and installing rigids, which produce much more light. headlights didnt cause any interference though. i haven't had any issues in that regard either
  #128
Old 10-11-2015, 06:23 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
All the kits i buy are less then $100, one of the kits i bought in '07 and is still on the same bulbs, ballast and relay and the kit has been on two trucks.
  #129
Old 10-11-2015, 08:21 PM
2112's Avatar
2112
2112 is offline
Obviously, I am choosing the wrong ones.
I gave up. Having projectors made.
  #130
Old 10-12-2015, 11:16 AM
xmontex4's Avatar
xmontex4
xmontex4 is offline
That's the best way much better light output and quality! I had them installed in my F250 they look killer.
  #131
Old 10-13-2015, 06:27 PM
Trophy_23's Avatar
Trophy_23
Trophy_23 is offline
How are these lifetime LEDS holding up? I am still waiting for a headlight bulb to go out so I can upgrade
  #132
Old 01-20-2016, 10:13 AM
rickvm's Avatar
rickvm
rickvm is offline
I Have an 02 excursion with stock clear or aero housing. which way do i face the led light? up ,down or side to side? thanks
  #133
Old 01-20-2016, 01:35 PM
rickvm's Avatar
rickvm
rickvm is offline
I think i got it figured out. Should be side to side,same reflector position as 05-07 just a little wider(top to bottom). Have to wait till it gets dark to check,but should work. originally had them pointing up and down but didn't look right. A little cut out tool work to the bulb insert plate so the bulb would face the right way,didn't take long. check back in later with results.
  #134
Old 01-20-2016, 01:42 PM
sxrfun's Avatar
sxrfun
sxrfun is offline
I installed led's in my 08....yes you want the led's at the 3 and 9 oclock positions in order for them to work properly.
  #135
Old 01-20-2016, 06:40 PM
2112's Avatar
2112
2112 is offline
Anyone have the latest coupon code for Lifetime?
Quick Reply: Lifetime LED Headlights (Review)
