Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Headlight Bulb Reviews
Reviews and comparisons of top products
Lifetime LED Headlights (Review)
#62
i don't believe drivers are utilized in this application (not 100% sure on this), as the source for power is DC, drivers are typically used when the source is AC, in which case it must be converted to DC for the LEDs to illuminate
#63
I got some fog lights for my Expy on amazon and they were very good quality and have a really good output. They were a tower with a few leds facing out to light up the housing and a projector on the end with 4 leds inside and they are better than the headlights...granted one is out and the other doesn't work well lol.
#64
while it is true that LEDs generate a huge amount of heat, the heat is NOT thrown forward, thus the large heat-sink and fan behind the LED. based on my knowledge of LED function, i would have say that these guys are right and that they do not generate enough heat to thoroughly melt ice in said conditions.
No, they are heat sinks. In a typical led light you have your conical reflector dishes, and about 1/4-1/2 inch of space for a circuit board. The back of that is attached with thermal paste to an aluminum block which dissipates heat to the heat sink.
LEDs do generate a LOT of heat.
LEDs have been around for a long time. You only recently have seen them become high intensity as we just started being able to control the heat.
The issue with LEDs not melting snow is two fold,
1) low intensity LEDs like blinkers won't produce enough heat to melt snow
2) led headlights and off road lights do, but dissapate the heat rear word through heat sinks.
I invite you to touch my light bar after a night ride.
#65
#66
#67
I sort of like the LED idea.
The only problem around here is when it does
snow it's that wet stuff that sticks to everything
and then freezes hard. Wiper shakers come to
mind at times like that. I would not want to have
to go out every few miles and clean the headlights too.
Maybe someone will come up with headlight heaters
or a set of wipers with shakers to clear the lens.
Sean
Sean
#69
I admit I didn't read every single post in this thread, but I did just install a set of the Lifetime LED H13 70W 3200Lumen lights in my stock 2008 F250 housings.
They fit right in with no problems. The low beam side is facing to the fender side of the housing reflector and the high beams use the whole housing reflector (fender side and grill side). I haven't been flashed yet. Hopefully, my description of low beam / high beam is understandable.
These lights are fantastic. Thank you OP for starting this thread. I wouldn't have known about them except for your review.
I also have to say that Lifetime LED has been very good to deal with. The first set of lights they sent me had obviously been used and returned. They were greasy with messed up connectors and the fan was really loud on one of them
When I sent them an email telling them about the set they sent they responded that it was their mistake by sending them out. They then sent me a new pair with a return label in the box. They took ownership of the problem and made it right without any issue.
#70
Good to hear they made it right for you and they're standing behind their product I've been contemplating these lights since this theard started just having a hard time dropping 150 bucks on a set of light bulbs especially since if I do the headlights I'll want to do the fogs too they gotta match you know
#71
I've got Sound Off Signal fog/flood lights in the bumber opening and Rigid D2 Hyperspots in the stock fog light location. Everything looks to be abut the same temp as the Lifetime LED Superbright Headlights.
I was about to replace the Sylvania Silverstars with a new set since they only last about two years for me. At $50 +/- a pair I thought I'd just put the money toward LEDs. I think it was a good choice. These LEDs blow the Silverstars away.
I went with the H13 Superbright LED headlights at $249.00. I wanted the 70watt brightness. If you use a coupon code it will take some of the sting out of the purchase. I used this code: PIRATE4X4 and it took $24.90 off the
price. That paid for shipping and then some. I don't know if that code is still current, but I used it less than a month ago.
#72
I know I don't flash my high beams many times even if I am being blinded.
I think the only way to really tell is to have the wife or buddy coming at me with my own truck out here in the boonies.. I would just hate to drop a lot of money on a lighting solution that was potentially dangerous to others...
Glad to hear that the reports on the new style reflectors are good!
Still watching and waiting...
#73
I had a set in my 1988 Ranger that were 85/125 per side.
They were pointed way down at the ground. Lost of controlled
light on the road right in front and not going down the road.
BUT flash me and you were in for it. I had even checked it
out at night with a friend driving by me and was ok.
I only wished that they were what they used in the newer trucks.
Glass Hellas with the good metal reflector and cutoff shield.
On high beam I could turn off the next door neighbor's night lights
on there driveway. But on low they stayed on. Worked really well
out in the woods at night. You could see the big critter in the road
before you hit it. I think in the last 30 years I have hit 3 deer,1 dog,
1 cat,1 owl and enough bugs to fill a trash dumpster.
One of the deer hit me. Ran right into the side of the truck. The dog
I just bumped and the poor cat ran out and went under my little VW
bug and got up and ran off. I did not kill any of the deer on the spot they
all ran off after. (NOTE : We have stupid deer here)
Anyway back to the topic.
Someone said that they had used the LEDs up in Alaska and did
not have any problems with ice over the headlamps. Have you been
out in the freezing fog with them also? I just don't feel that there is
enough heat to keep things clear. here we start with rain then sloppy
slush that freezes and then snow on top of all of that.
I can see cold snow not sticking once the temp is low enough so that
it does not melt the flake when it hits. Just worried that the stuff we call
snow here in Western Washington would stick and freeze on hard.
Sean
Sean
#75
