Ride Quality Info - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Ride Quality Info
Old 03-30-2014, 08:20 PM
2013SD6.2 2013SD6.2 is offline
2013SD6.2 is starting off with a positive reputation.
Ride Quality Info
Well, I purchased a new 2013 250 6.2 Lariat it had the heavier pay load suspension minus over loads. Anyway, I always thought it rode insanely rough. Today, I purchased a 2014 f250, this one is a lariat, heavier pay load suspension minus overloads, but it has the fx4 package with the upgraded rancho (white/red) shocks. The ride quality is day and night difference. Instead of hitting bumps and thinking you ran over a large rock, it just glides and absorbs the impact. The rear end of the 2013 would always bunny hop over bumps with the impression that it was bouncing so hard that the wheels was leaving the pavement. Keep in mind both trucks are the same except 6.2 vs 6.7, Lariat vs fx4 Lariat, same wheels and tires on both trucks. Is these shocks really making that big of a difference??????
Old 03-31-2014, 09:20 AM
Mmaxed Mmaxed is offline
Mmaxed is gaining momentum as a positive member of FTE.
Shocks can make a big difference.
Are the tires the same brand?
The same pressure?
The diesel engine is a lot heavier. Makes a big difference in the front, but I would think not much in the rear.
Old 03-31-2014, 12:59 PM
snelldawg's Avatar
snelldawg snelldawg is offline
snelldawg is starting off with a positive reputation.
Those shocks are 'Rancho-branded'. The only thing different between those shocks and the non-FX4 shocks is the color.
I'd guess that the additional weight of the 6.7 is giving you a better ride and the shocks, although inadequate for these trucks, are still new and are somewhat performing.
Old 03-31-2014, 08:36 PM
SoYouCanSuperDuty's Avatar
SoYouCanSuperDuty SoYouCanSuperDuty is offline
SoYouCanSuperDuty is starting off with a positive reputation.
Odd... My 2013 F250 6.2L XL rides like a dream....
Old 04-01-2014, 01:31 PM
Amelio's Avatar
Amelio Amelio is offline
Amelio is gaining momentum as a positive member of FTE.
My truck is a '12 CC 4x4 SB I think it rides pretty good for a big heavy truck...it is a bit jarring over big bumps when empty. Last summer I had 1,200 pounds of rock in the bed and it made for such a smoother ride.
This is to be expected......
I plan to go 20" wheels with 35's and a 2.5" lift kit this summer and when I do I am going to change out my shocks. Don't know which ones just yet I have to do some research.
Just curious....why did you leave the 6.2 and go 6.7....aside from the ball busting powerg
Did you need more for towing or was it just a want?
I would love to have a 6.7....they just scare me with the repair costs after warranty and the fuel issues I hear/read about........plus I don't really need it.
Old 04-01-2014, 08:35 PM
Well, when I purchased my 2013 I was after the 6.7 but was not any on the lot to my liking. So I settled for the 6.2 lariat crew cab, lol it had everything but the engine I wanted. I don't tow/haul every day by any-means but when I do, it's ball busting. 10-16k depending on the size of equipment. I loved the 6.2 because it was a no hassle get up and go every day but when it came to raw grunt it just didn't have it. Now let me say this, I want my power down low on rpms not up high screaming like the 6.2 is. Driving the 6.2 in hills empty just seemed like I as always in the fuel a lot. (3.73s). Has mileage was little low, 12s-13s. This new truck has the power, and the mileage. 16s-18s. 20s on flat land 4 lanes. Now with the 6.7 it requires a little for thought. Idle down before shutting it off, warming up, def fluid, more rapid fuel filter changes, draining water out of the water fuel separator. diesel costing almost a dollar more a gallon. U get my drift, just all in what u want.
Old 04-03-2014, 06:40 PM
Sargemo105's Avatar
Sargemo105 Sargemo105 is offline
Sargemo105 is starting off with a positive reputation.
Shocks
I'm one that was disappointed with the harsh ride of my truck when driving without a load. Today I took delivery of four Bilstein shocks and hope to get them installed in the next two weeks.
My complaint is the hopping the rear would do over large bumps, and the constant up/down in the cab over smaller bumps over less than ideal roads. On a recent trip my wife and one of my kids actually got 'truck sick' from the repetitive motion.
I spoke to three Ford truck owners that installed Bilstein shocks and they describe the improvement as dramatic. Unfortunately I can't compare apples to apples since they did not have the same gasser I have. I'll provide an opinion after the install.
Old 04-03-2014, 07:48 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
I did the Bilstein on the rear, A little better...but not really worth it IMHO.
Still hop around on the bad roads around here. Normal bumps not a problem. I'm running 60 psi on the Rears and 60 in the Fronts. Truck calls for 60 front and 70 rear. 70 in the rear is out of control.
Old 04-03-2014, 10:37 PM
8iron 8iron is offline
8iron is starting off with a positive reputation.
The Diesel makes a big difference in ride quality. My lariat 6.2 rides like a dump truck. I added a set of Rancho 9000xl and it helped with the rear end hopping but it's still rough.
Old 04-04-2014, 01:45 PM
DHPRO's Avatar
DHPRO DHPRO is offline
DHPRO is starting off with a positive reputation.
HEH...my 14 Platinum rides like a dumptruck! Its like a rock across a pond when I hit bumps on a high speed turn.
Old 04-04-2014, 09:35 PM
Thenewboss's Avatar
Thenewboss Thenewboss is offline
Thenewboss has a good reputation on FTE.Thenewboss has a good reputation on FTE.
All of my upgraded suspension equipment is in my signature. That said, my biggest problem with the stock set up is the bump steer (death wobble?). Grille guard up front and the cap on the back has really planted the truck firmly on the road.
Old 01-18-2015, 06:58 PM
chrislambing chrislambing is offline
chrislambing is starting off with a positive reputation.
my 2011 f250 rides like a tank
Just joined This site although I've trolled thru looking at info on super duties when I was buying mine. I recently bought a 11 f250 6.2 lariat fx4 cc. Long bed, it had 39k on it. I love the truck but one thing I noticed was it rode like a tank! I know it's a 9900gvwr with 35s but it's ridiculously rough. I immediately put new shocks on it, I went with Gabriel reflexes and it helped a little but not much. I'm also wondering if the 35s affect the ride quality that much, I hate to be complaining about the ride on a truck this size, but dang it's rough!
Old 01-18-2015, 11:53 PM
RumpityRump RumpityRump is offline
RumpityRump has a good reputation on FTE.RumpityRump has a good reputation on FTE.
Quote:
1st do the free thing......let out some air. if running 50, try 45 for 2 days, then 40 for another 2 days. I bet you will feel a lot of the difference. It's a free try.
Old 01-19-2015, 11:56 AM
Gints Gints is offline
Gints is starting off with a positive reputation.
+1 for that, psi on door jam is for loaded, no wonder it jumps like grasshopper. Let some ear out,especially in the back.
Old 01-19-2015, 08:11 PM
Crumm's Avatar
Crumm Crumm is offline
Crumm is gaining momentum as a positive member of FTE.
Yep tire pressure makes a huge difference. First thing I did on my 2015 is to let the air out of the tires and then the second was to take it in and get the TPMS pressure turned down.
F250 vs F350 ride quality and mpg e23barton 2017 Super Duty 21 12-30-2016 07:18 PM
new ride itiscosmo 6.7L Power Stroke Diesel 21 09-05-2015 03:53 PM
fx4 suspension vs lariat theoshin 2009 - 2014 F150 22 06-28-2013 08:51 PM
Suspension differences between F350 SRW Lariat and FX4 2008-2009 Mystic_Cobra 1999 to 2016 Super Duty 6 12-01-2008 07:17 AM
FX4 vs Lariat Ride SDTruckMan 2004 - 2008 F150 10 07-27-2005 12:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
