6.2L V8 Discuss the 6.2L V8
Ride Quality Info
Old 01-19-2015, 08:22 PM
devongarver's Avatar
devongarver
devongarver is offline
A few things...
As others have said, the weight of the diesel makes a big difference, it will ride smoother than the gas given an identical truck configuration. Also, not sure what wheels/tires were on each truck-shorter sidewall or AT tire will ride harsher than taller sidewall and touring tire normally, but obivously as the guys have said, air pressure makes a difference. Don't go too low though, as your tires won't wear correctly, and you will chance being caught with your pants down so to speak, if you are out and decide you need to load something heavy in the bed...you would need to air up or risk tire failure. As for the "Rancho Shocks"...they are junk. Not even an "off road" shock. Even if they weren't junk, a shock will only do so much to unloaded suspension. I am running Bilstein 5100 HDs all around and they really didn't make THAT big of a difference unloaded. When loaded...holy crap do they make a difference. Lastly, a rear sway bar makes a HUGE difference with the bunny hopping over bumps. I put one on my last truck and it was night and day. I don't know offhand, does the new truck have a rear sway bar?
Old 01-20-2015, 08:24 AM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is offline
Pressure inflation chart
OEM factory installed 275/65R18E (626revs/mile):
35 = 1940lb
40 = 2130
45 = 2310
50 = 2535 (C)
55 = 2660
60 = 2825
65 = 3000(D)
70 = 3150
75 = 3305
80 = 3415 (E)
My rear axle is carrying 3,000 lbs (per cat scale)
Loaded for camping it is 4,100 lbs (per scale)
I run 60 psi in my rear tires,which is enough for my weight, and it is a much better ride empty. 60 psi is good for 5,650 axle weight.
Old 01-26-2015, 04:15 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Originally Posted by Sargemo105
I'm one that was disappointed with the harsh ride of my truck when driving without a load. Today I took delivery of four Bilstein shocks and hope to get them installed in the next two weeks.
My complaint is the hopping the rear would do over large bumps, and the constant up/down in the cab over smaller bumps over less than ideal roads. On a recent trip my wife and one of my kids actually got 'truck sick' from the repetitive motion.
I spoke to three Ford truck owners that installed Bilstein shocks and they describe the improvement as dramatic. Unfortunately I can't compare apples to apples since they did not have the same gasser I have. I'll provide an opinion after the install.
How did the install go?? Did the Bilstein 5100 make a difference??
biz
Old 01-27-2015, 05:05 PM
ssregal39's Avatar
ssregal39
ssregal39 is offline
I have a 14 6.2 long bed 4x4 xl extended cab but it came with the camper package with overload springs and rear swaybar. It rides very rough.
I was perusing the upfitter guide and these springs are very stout. With a small load it will bounce on the overloads. I was thinking about ordering softer fronts and rear springs as i don't tow/load heavy yet, expensive though.
It definitely needs shocks with much better rebound control to keep the tires on the road instead of bouncing in the air and tripping traction control.
Old 01-28-2015, 08:39 AM
airm4n's Avatar
airm4n
airm4n is offline
I changed mine on 2011 350 from factory to gabriel max control along with rancho steering shock. Ride improved night and day with those. I think i paid around 90$ a shock or so for each of the 4 corners and 70$ or so for the steering. All CDN prices.
Old 02-04-2015, 05:23 PM
chrislambing's Avatar
chrislambing
chrislambing is offline
Originally Posted by devongarver
A few things...
Yeah it does have the rear sway bar, how low is too low on the tire pressure. I carry about 500 lbs of tools in 3 boxes in the bed at all times. Thanks for the response.
Old 02-04-2015, 05:25 PM
chrislambing
Originally Posted by Mmaxed
Shocks can make a big difference.
Are the tires the same brand?
The same pressure?
The diesel engine is a lot heavier. Makes a big difference in the front, but I would think not much in the rear.
Yah all the tires are 35 falken wild peak ats, running@ 65 psi,
Randall 458
2017+ Super Duty
45
01-31-2017 08:09 AM
Michaeltharris
1999 to 2016 Super Duty
01-07-2011 11:53 PM
slc10844
2004 - 2008 F150
06-30-2009 11:42 AM
chi6488
09-24-2006 09:13 PM
paver1960
01-31-2004 12:34 PM
Quick Reply: Ride Quality Info
