Dual tensioner upgrade mod done w/pics
#31
I used a thinner wheel and it suffered no build-up, but I could see a thicker one possibly doing that.
#32
Kevin
#33
#34
Yeah I read an article about that once Phil.
And sure enough its one of the top links when i searched for it.
Grinding Aluminum
Grinding Aluminum
#35
I had the dreaded "chirp-chirp" from the front of the truck on the way home last week and limped into the driveway. I figured it was just a pulley, but after lots of reading, I found that the OBS tensioner is a high wear part and there is a TSB (98-23-14) for the newer and improved SD style dual-arm tensioner. Even though my tensioner still had some life left and it was indeed only the lower idler pulley that was trashed, I considered it prudent @140k miles to perform the update and be done with it. I would also need a new 122.7" belt.
I found lots of great info, but it was spread around, so I thought I'd try and collect some images of my job into one post. I've uploaded a few images of the task to an imgur album (including a copy of the TSB). Maybe I didn't find much because it is so darn easy and also many folks did the upgrade so long ago that links had expired.
Well, here's a fresh one:
truck tensioner images - Imgur
Descriptions of the upgrade and a copy of the TSB are in the album's images.
Here's also a video of it running:
Ford OBS 7.3 Powerstroke dual-armed tensioner upgrade running - YouTube
Parts used:
(Ford) F8TZ-6B209-BA Dual Tensioner (F-Series) Pickup
(Ford) F8TZ-8620-FB Belt (F-Series) Pickup (JK8-1227)
Since I can't think of everything, please tell me what I may have missed or just post your ideas on this mod.
Thanks everyone even though you didn't know you helped, just like I hope this will help someone else.
DS
Parts used:
DS
Thank you, again. Great info!
Rusty
Smokin'
40
07-13-2006 07:42 AM
