Gasoline in a diesel engine = best mileage ever? - Ford Truck Enthusiasts Forums
Old 03-30-2014, 02:35 PM
parkland parkland is offline
parkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud ofparkland has much to be proud of
Gas-powered diesel engine may double fuel efficiency - SmartPlanet
There are a lot of articles saying that a diesel engine running on gasoline is the next best thing since sliced bread.
Obviously, they must be using different fuel pumps than the stock diesel setup, because we all know that gasoline can grenade fuel pumps on a diesel.
That being said, what if we mixed gasoline with a bunch of 2 stroke oil, or engine oil, or fuel additive to get the gasoline to the same lubricity as diesel oil?
Anyone ever tried it?
The results look promising enough to want to know the answer.
Old 03-30-2014, 03:34 PM
Old 04-06-2014, 12:49 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
well, we know that diesel contains more energy per gallon than gasoline, so i don't see this being more efficient.
as for putting a carb on top of a diesel, well how do you feel about blowing up your engine - the heat of compression would ignite the fuel mix way too early and have nasty detonation effects on the engine.
doesn't look like one i would want to try unless my goal was experimenting on something that was about to be sent to the crusher anyway
Old 04-06-2014, 11:11 PM
Quote:
Diesel also costs more than gasoline now, and requires a more expensive heavy engine to do the same work.
All jokes aside, the article seems interesting.
Old 04-11-2014, 07:15 PM
Misky6.0's Avatar
Misky6.0 Misky6.0 is online now
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Quote:
True, but it's only 10% more this week. Gas $3.65 vs. Diesel $4.01 happy dance
Sent from my Sprint PC36100 using IB AutoGroup
Old 04-11-2014, 07:27 PM
Granted the ecoboost is only available in the f150 now, but if they make say a 500 hp 5.0 ecoboost for the superduty, IF, there might not be much reason to buy a diesel truck.
MPG is nice, but crap it would be nice if diesel went back to being cheaper than gas for F*** sakes already.
With soaring diesel prices, and the diesel option costing so much more, along with modern engine reliability issues, who knows.... all I know is I'm interested in hearing promising leads on alternatives haha.
Old 04-27-2014, 02:09 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
Diesel Rug blends have been done when using WMO to make it start easyer, I have ran 60% virgin motor oil Diesel blends with no problems is stock fuel system in 91 Idi, your 6.o should have plastic fuel lines, so should be ok to run BIO, ford says no more than 10%....throw that truck away and get a Idi, when diesel gets more expensive just burn suntan lotion.
Old 04-27-2014, 08:29 PM
Quote:
Even brand new engine oil is going to be less than diesel very soon if not already. Think that will be enough lube for the HPFP?
Old 04-29-2014, 12:15 PM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
I'm still curious how you manage to make that cost effective.
Old 05-03-2014, 09:26 PM
Got the virgin oil for free......
Old 05-04-2014, 01:23 PM
Where I live virgin oil is now cheaper than diesel fuel, so any mixed in would be more cost effective since engine oil has more BTU's than diesel.
Old 05-04-2014, 06:29 PM
flainn's Avatar
Sweet deal if you can get it...
Now, when you guys say "virgin oil", what exactly are you talking about? What weight?
And Parkland, I'd be hard pressed to find any new motor oil that costs less per gallon than diesel. Even buying it in 5-gallon buckets it still costs $12 a gallon or so. What's your secret?
Old 05-05-2014, 11:05 AM
Gas station : Diesel 1.45 / liter
Walmart 15w40 : 20 liter pail for 30$
Old 05-05-2014, 05:52 PM
flainn's Avatar
I'm confused ... because doing the math, it looks to me like the oil is still costing you more than pump diesel.
Assuming you're using US gallons (maybe you aren't),
3.78541 L / gallon
Diesel $1.45 / L
1 gallon diesel = $5.49
Oil:
20 liters (5.28344 gal) for $30
Or $5.68 per gallon
Old 05-07-2014, 12:34 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
^^^^ Um, the math is easier if you DON'T convert to gallons. 20-liter pail of oil for $30 is $1.50 / liter, 5 cents a liter more than the diesel. So it's close.
Stateside, we're paying aprx. $4/gallon for diesel. The "pails" of oil here are 5-gallon, and even the cheapest oil is aprx. $40/pail, so about twice the price of fuel. So Canada is experiencing cheaper oil, and more expensive fuel, than we get.
So why does that article, after talking about getting rid of the throttle and spark plugs, show an animated diagram of an Otto-cycle engine?
V10 Gas vs Diesel "The Truth" Budkole 1999 to 2016 Super Duty 374 07-11-2015 12:50 PM
Emergency! Gasoline in the my diesel fuel... F357 6.0L Power Stroke Diesel 48 02-22-2015 04:08 AM
Diesel Engine Running on Gasoline?! What? lud04X General Diesel Discussion 14 07-08-2014 01:35 AM
Food for thought, or perhaps, no food for thought... quaddriver General NON-Automotive Conversation 23 06-09-2014 11:50 PM
What are the Different Types of Gasoline | New Orleans, LA lamarqueford Performance & General Engine Building 1 02-22-2014 01:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
