What brand fuel pump?
I used this NAPA pumpNAPA AUTO PARTS which is a Carter on mine it's still doing a great job . and it's showing in stock .
When I replaced my fuel pump a few months ago, someone recommended the Airtex E2236. I ended up getting one of the last Bosch pumps on Amazon however, so I don't have any personal experience with Airtex. Whatever you get, make sure it is rated for diesel fuel. I had a Walbro pump that crapped the bed after only 20,000 miles or so.
Thanks for all your replies. I went with a precision from the Irish store for $150. Made in the USA is stamped on the metal shell. I was in shock to see this.
The one I took out was a Carter brand, also stamped with Made in the USA. I know it is at least 7-8 years old as I have never changed my fuel pump.
I had a stock bosh pump run at 110 psi for 8 month . And a airtex run 110 psi for about 2 months before i found out i had double the psi haha so i think their both good pumps. I just dont see their being much of a difference between the pumps,my truck ran the same with both. Their are some pumps on ebay for under $50 if you needed a backup pump or were going to run a dual pump set up
O'Reillys doesn't carry the airtek pump anymore even though it's still listed on their website. I asked why and of course they had no idea, said it was a corporate thing.
They all perform well when new, but mine had over 6,000 hours on it (estimated) when I pulled it... and it still worked fine on stock sticks. I replaced mine only as a precaution to protect my brand new Stage II injectors.
That's the one I went with too. It's only been a week but it seems to be doing alright for now. I'll hook by fuel pressure gauge up when I get a change and compare psi to Bosch. O'Reillys doesn't carry the airtek pump anymore even though it's still listed on their website. I asked why and of course they had no idea, said it was a corporate thing.
I can say the Carter pump has always been noisy for the 8 years I've owned my truck, but it never let me down until yesterday.
