The Do-over - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
The Do-over
Old 03-29-2014, 05:00 PM
Fordman96 Fordman96 is offline
Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.Fordman96 has a good reputation on FTE.
The Do-over
Long story short: Had an old build thread, it was a mess, so new year, same truck, we're starting fresh.
The truck: 1996 Ford Bronco XLT (pictures to come)
Mass Air Flow 351Windsor:
-Hedman long tube headers, MSD plugs/wires,
-K&N air filter
-301,000 miles (no smoke, no leaks)
E4OD transmission married to a BW1356 manual shift t-case.
-Rebuilt in 2013, has ~4,000 miles on them both
Axles:
Front - Dana 44 TTB. 4.10 gears. stock internals
Rear - Ford 8.8. 4.10 gears. Stock internals
Wheels/tires - 33" Pro comp A/T's with 15" Wagon wheels
Body:
- "DISASTER"
Frame:
- Solid yet typical rust covered
Old 03-29-2014, 05:19 PM
Upgrades: (I am willing to take all opinions/advice - Negative/positive)
Engine:
-Turning the old 451W into a 408w (Got talked out of all other engine choices)
-Get tuner
-Air raid intake? (Dry not wet)
-Forced induction? Price v necessity
Parts: (90% summit racing)
-Probe pistons (PN:PBP-12355-030)
-BBK Power plus series throttle body (PN:BBK-1503)
-Comp cams Xtreme energy camshaft (PN:CCA-35-320-8)
-TFX Fuel Injectors (PN:TFS-89024)
-Trick Flow R-Series intake (PN:TFS-51511004)
-Federal Mogul Re-ring kit (PN:FEM-2056116M311)
Edelbrock Performer RPMs Aluminum Heads 170cc ported, double spring (no rockers but PO had aluminum 1.6 rockers)
Summit wish list didn't save my rocker choice so I will have to find those again
Transmission/t-case:
-Untouched (maybe shift kit)
Axles:
Front - Dana 60 High Pinion (Found one in Fenton $700 with 4.10s)
Rear - Sterling 10.25 (Still looking, haven't checked boneyards)
Want to try for 8-lug, all disc brakes
Body:
Exterior:
-FiberwerX Fiberglass fenders ($350 for pair)
-FiberwerX Fiberglass quarterpanels ($400 for pair)
-New tailgate shell
-Possibly try to sand frame
-Redo last years mistakes on doors, hood and roof
-Weather stripping
Interior:
-New door panels
-Repair/replace all trim pieces
-Upgrade seats? (Newer seats - Leather v cloth)
-Rubber front flooring, redo bed liner in rear
-Replace center counsel with fabricated one
Electrical:
-Electronic door locks (quit working 1-2 years ago)
-Blower fan only works on high
-Replace bulb in gauge cluster
-check on rear defroster
-Replace exterior tailgate window switch (only works one way)
-Rewire front foglights
-Wire new foglights
Old 04-01-2014, 04:42 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
I'll bite . I like build threads some times. My own is a few pages deep but I haven't touched it in a while. Maybe one day I'll re-read though it all...
Old 04-01-2014, 05:47 PM
The biggest hold ups right now:
1) weather
2) crappy welder
3) garageless
Old 04-03-2014, 06:08 PM
richard1586 richard1586 is offline
richard1586 is starting off with a positive reputation.
I have an Eddie Bauer edition (Mocha) passenger side interior panel for electric windows and door locks. $125 plus shipping.
richard72942@gmail.com
Old 04-03-2014, 07:32 PM
I think I'm going to make fiberglass door panels, seen a few things and I like how I can make it how I want.
Old 04-13-2014, 09:25 PM
Well it's been a while, but it has been difficult without a garage/coverage from the weather. Been having a passenger rear brake issue so I took that apart.
The whole brake had disassembled itself on the lower half. It dislodged the adjuster and that got squished between a bad and the drum, grinding it down to unusable. The lower spring and adjuster cable were off, but the top springs stayed on. After fixing it (took way to long since it's been.. too long) It was fine and dandy for about a day. I loosened it up and had some issues sliding the drum back on (the pads refused to squeeze together on the bottom.)
Now when I roll backwards it's fine, but going forward it drags like crazy and the brake is hot hot hot! I stopped at a self wash to clear off some fluid on the rear axle, felt the driver side drum (after 20-25min drive) and I could touch the drum. Felt the passenger side and it burned my hand which was about 3" off the rim. Suggestions?
Old 04-13-2014, 09:34 PM
Saturday I was able to get over to the Hudsonville parts swap for a few hours
Saw some very beautiful trucks (will post pics.) and of course picked up some nice parts.
Blacked out grille - $10.
Beauty rings - $10 ea.
Universal flexi lite fan - $10.
8 lug front axle (forgot to get more information on it :banghead ) So I'm hoping to get some serial numbers on it. - $150 came with 2 sets of hubs, 2 sets of spindles, 5 lockouts, and leaf spring mounting brackets.
Also got a nice Dick Cepek light bar to replace my other one - $100
As for work, I got one mounting side of the light bar off, sanded (wish I could have media blasted it,) primed and painted with some stainless steel rattle can paint.
While waiting for layers to dry I got the passenger side of the axle torn down the spindle before it rained. More to come!
Old 04-14-2014, 05:10 AM
Did you replace the star adjuster? Also I'd recommend putting antiseize on it so it will adjust better. Also, how new are the wheel cylinders?
Old 04-14-2014, 11:11 AM
The wheel cylinder on that side is brand new because it went bad late last year. I replaced all the springs, adjuster and cable with new parts too since I got the kit.
Old 04-14-2014, 05:50 PM
Today I swung by the local pick-apart. Got a new headlight assembly/bezel with the trim piece underneath for $80 (pics tomorrow) and a 3/4 or 1 ton 8 lug rear axle for $250. They were very unknowledgeable about it.
Got the other side of the front axle torn down to the spindle and with the winter weather heading in that's where I had to stop. Didn't get a chance to work on the other mount for the light rack either.
Now it's on to researching what part numbers I could on the axle.
http://www.ford-trucks.com/forums/13...tion-help.html
any help is appreciated.
Old 04-14-2014, 07:32 PM
Today I made a discovery. In reverse the truck doesn't drag, but when I go to drive, (occasionally) it makes a clunk then it starts to drag.
Old 04-15-2014, 01:02 AM
It's probably something simple but I can't think straight right now. I've been awake for over 24 hours now... my brain is toast.
Old 04-15-2014, 08:04 AM
That's okay after I get the new axle, I will convert it to disc brakes and be done with drums on this truck forever.
Now discs all around means I have to change the master cylinder correct?
Old 04-15-2014, 12:22 PM
I'm not too sure, I remember seeing something about changing the pressure switch(I forget the name). A master cylinder upgrade might not be a bad idea anyways.
Clark 285v33/BW 1345/Gear Vendor Overdrive/4.10 rear end WhitefishBoy64 Clutch, Transmission, Differential, Axle & Transfer Case 1 01-20-2012 07:09 PM
GVCW - towing capacity 1987 F-350 7.3L diesel nebula aluben Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 02-10-2011 07:38 PM
1975 F250 Gas milage paintballer20 1973 - 1979 F-100 & Larger F-Series Trucks 15 01-04-2010 07:38 AM
3.73 to 4.10 gear change MC9 1999 to 2016 Super Duty 19 08-16-2009 12:07 AM
3.73 vs 4.10 DRW VS SRW AND A POWER STROKE jeciv Fifth Wheel & Gooseneck RV Towing 3 09-06-2001 01:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
