rear glass install - Ford Truck Enthusiasts Forums
rear glass install
Old 03-29-2014, 03:11 PM
elkarcher1716 elkarcher1716 is offline
elkarcher1716 is starting off with a positive reputation.
rear glass install
so i am trying to figure out how the rear glass gasket goes on the glass and then in the hole. anyone replaced them before? hoping someone can shine some light on the subject.
Thanks Tim
Old 03-29-2014, 03:58 PM
march's Avatar
march march is online now
march is gaining momentum as a positive member of FTE.march is gaining momentum as a positive member of FTE.
Old 03-29-2014, 05:57 PM
84espy 84espy is offline
84espy has a good reputation on FTE.84espy has a good reputation on FTE.
The seal is a tight fit around the glass, but it will go on. Having 4 hands are better than 2 and, if you have the means, using suction cups works much better for the guy holding the glass in place. I used some soapy water and 1/8" vinyl covered steel wire to put the glass in place.
Old 03-29-2014, 07:48 PM
My seal looks nothing like that at all. Have to call JBG on monday. Thanks for the video
Rear elec sliding glass? Amicus 6.0L Power Stroke Diesel 1 09-02-2016 08:23 PM
Glass Measurements Gotanoldtruck 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 03-19-2014 06:22 PM
sliding-glass or solid rear glass? Truckmano5 1973 - 1979 F-100 & Larger F-Series Trucks 27 02-01-2013 03:32 AM
Inside glass hatch opener PoPs 03DEX Excursion - King of SUVs 9 10-09-2007 12:39 AM
rear glass BOJOFASO 1978 - 1996 Big Bronco 2 11-17-2004 05:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
