navigation radio - Ford Truck Enthusiasts Forums
navigation radio
Old 03-29-2014, 01:13 PM
Mojos150 Mojos150 is offline
Mojos150 is starting off with a positive reputation.
navigation radio
I have this navigation radio. But I'm having trouble with it. When I installed it it would power up and then turn off. Also upon installing it and powering it up my dash lights blew. I like this radio but I'm not sure it will work. Any suggestions?
Thanks BTW I have a 2007 F150.
Old 03-29-2014, 03:14 PM
twfish twfish is offline
twfish is gaining momentum as a positive member of FTE.
That looks like the factory nav system right? Have you tried adding a heavier fuse? That takes alot more power than a normal one. You dont want it ill be glad to take it of your hands! Hahaa
Old 03-29-2014, 03:22 PM
Lol by adding a heavier fuse would I risk damaging anything?
Old 03-29-2014, 04:52 PM
Have you tried reinstalling it? Something might not have been hooked up right. Id do that then try a heavier fuse
Old 03-29-2014, 07:14 PM
The good thing about the install is that there is only two plugs that can go in the back of the radio. So the install isn't too bad. I just don't want to reinstall a new fuse before I can come up with a solution.
Old 04-06-2014, 07:05 PM
390XR7's Avatar
390XR7 390XR7 is offline
390XR7 is starting off with a positive reputation.
Don't install a bigger fuse all you will end up doing is melt your wiring.might have a short somewhere,can you take the radio to someone and have them bench test it for you?
Old 04-06-2014, 09:35 PM
thzpcs thzpcs is offline
thzpcs is gaining momentum as a positive member of FTE.
Test for continuity and resistance on the 12v rail. Also, the suggestion for adding a slightly larger fuse isn't a terrible idea, but check to see what the current amperage on the blown fuse it. It might need a 10A fuse instead of a 5 to run properly
Old 04-06-2014, 11:18 PM
390XR7's Avatar
when I installed my factory Nav system I didn't need to change any fuses it was plug and play
2008 Ford F150 (Limited) SWAP with 2008 Lincoln Navigator GPS radio angeldiaz215 2004 - 2008 F150 2 03-24-2016 09:59 PM
Mysterious Plug Mojos150 2004 - 2008 F150 7 03-24-2014 04:17 PM
Satellite radio antenna madsonp 1999 to 2016 Super Duty 14 09-11-2012 02:03 AM
Any highly detrimental effects of tig welding these holes in this 6BTA block? stangclassic66 General Diesel Discussion 6 11-30-2009 03:40 PM
fiberglass topper storage? MoJo96 Aftermarket Products 5 07-25-2005 03:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
