Use 150 for plowing - Ford Truck Enthusiasts Forums
Use 150 for plowing
Old 03-28-2014, 10:12 PM
tjcprop's Avatar
tjcprop tjcprop is offline
tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.
Use 150 for plowing
Wondering if anyone uses their 150 for plowing and what brand and model plow? I use a Boss Standard Duty.
Old 04-06-2014, 09:47 PM
thzpcs thzpcs is offline
thzpcs is gaining momentum as a positive member of FTE.
I used a 150 for plowing for a while, but it's really hard on the trucks, especially if you're in an area with salt. After a few years it just ate right through the frame and the truck was bending in half. Just as a PSA, make sure you keep you trucks really clean and dry if you can after plowing.
Old 04-08-2014, 12:06 AM
Stanley Mitchell Stanley Mitchell is offline
Stanley Mitchell is starting off with a positive reputation.
Available on most 4x4 models equipped with the 5.0-liter V8 engine, the dealer installed package adds the wiring, cooling and other features needed to accommodate a plow up to 450 pounds.
Airbag Module Reset Tool
05 F150 with Boss plow - Can I add a bull bar without interfering with plow? kenp2600 2004 - 2008 F150 1 07-02-2013 07:21 PM
Light duty snowplow? Ford SD 1999 to 2016 Super Duty 10 09-18-2012 10:37 AM
Straight vs V snow plow defyrftr General Automotive Discussion 7 02-04-2012 06:13 PM
Looking for a Good Snow Plow PetermanJ 1987 - 1996 F150 & Larger F-Series Trucks 5 11-25-2009 10:52 PM
Snow Plow on 2000 F-150 trgcobra 1997 - 2003 F150 1 12-10-2003 12:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
