Hydra Issues - Ford Truck Enthusiasts Forums
Hydra Issues
Old 03-28-2014, 10:27 PM
Baatzy Baatzy is offline
Baatzy is gaining momentum as a positive member of FTE.
Hydra Issues
My Hydra arrived, and I tried to program it today, before installing it in the truck.
I got hydraflash downloaded and my chip seems to connect and work fine, but anytime I try to download a program to the chip it will go to about 20% but then will return with a window that says program error Unable to program position x.
x being whatever position I am trying.
Does anyone know what is going on? Did I miss a step?
I have tried this on 2 different computers, all there USB ports, and 3 different cables.
Thanks,
Baatzy
Old 03-29-2014, 04:42 AM
jps47's Avatar
jps47 jps47 is offline
jps47 is starting off with a positive reputation.
make sure you have the latest firmware and your hex code is right. Mine works flawlessly.
Old 03-29-2014, 05:36 AM
Tugly's Avatar
Tugly Tugly is offline
I'm a cautionary tale.
Tugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputationTugly has a superb reputation
Yeah... firmware is usually the fix.
Old 03-29-2014, 08:34 AM
I just updated the firmware this morning, or so it says it was successful. It still does the exact same thing though.
Any other good ideas guys?
Thanks,
Baatzy
Old 03-29-2014, 08:47 AM
Tugly's Avatar
When you load the programs, are they from the stock list... or are they custom?
If stock, how does your screen compare with these?
Old 03-29-2014, 08:55 AM
white Buffalo's Avatar
white Buffalo white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Is it possible the server/website at PHP is down and you can't download the programs?
Old 03-29-2014, 09:07 AM
Rich, my screen is pretty close to what you have shown, except my Hex code is VSAA4Q9 and the one in the recommendations area that you have circled is VSAA4R9. The Q seems to have the performance tunes while the R seems to have the speed limited tunes. Both have the high idle and whisper mode. Appears to be about 25 tunes between the 2 codes, nothing like what yours shows for the one hex code.
Rich from SD, I guess that does make sense, because it only ever gets to 20% and goes no farther. However, the firmware seemed to have no issue updating so I don't think the server is down. Or maybe they have multiple servers
Thanks,
Baatzy
Old 03-29-2014, 11:22 AM
Did you go through the activation & registration section under the help tab to register your hydra chip?
if so what is your user ID showing? IIRC all users will yield a 1 for the ID code unless purchasing custom tunes.
Here is a link to PHP's install video:
Old 03-29-2014, 11:58 AM
Baatzy,
Your only 30 minutes away from me in Sioux Falls - 20 after the chip install
You are more than welcome to stop by and I'll help you get it straight.......
Old 03-29-2014, 01:37 PM
I did register my stuff, but I have no activation code, but from watching the above video I was under the impression that the activation code is only needed if I am putting custom tunes on, which I am not, for now. If not, where can I find this activation code?
Rich, PM on the way shortly
Thanks,
Baatzy
Old 03-29-2014, 03:33 PM
Dan V Dan V is online now
Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.Dan V has a very good reputation on FTE.
Thanks,
Baatzy
I bought a Hydra used...and was able to log right in to the PHP server without registering/activating anything.
Old 03-29-2014, 06:02 PM
I'm wondering if your software is not connecting online. Bill mentioned that on his website, something to the effect of "make sure your antivirus software is disabled during software installation or make sure the antivirus software is not blocking the Hydraware from accessing the internet"
What indicators do you see on the bottom toolbar?
Also, under the Help menu/registration - what does your user # say?
Old 03-30-2014, 09:36 AM
Hwood121 Hwood121 is offline
Hwood121 is starting off with a positive reputation.
I had the same issue when I first got my Hydra. Contacted PHP and turned out one of the memory chips was bad. PHP overnighted a replacement and all is well. Give them a call.
Old 03-30-2014, 10:37 AM
Tugly's Avatar
Another thought: Turn off your antivirus software temporarily and re-install the software. Keep your AV software off while you run HydraFlash, then re-start your AVS when done.
Old 03-31-2014, 07:01 PM
Well Nathan (Baatzy) came over today and we had no luck trying to load the tunes on his Hydra chip using my laptop as well. I was able to change my Hydra tunes around but when we plugged in his chip it would always stop at 20% like he posted.
So we called PHP and it seems to be the same situation Hwood121 experienced. PHP said Nathan's chip was showing symptoms of a bad chip and that they would send him a new one.
*SOLD* PHP Hydra and USB Cable Hwood121 Ford Truck Parts for Sale 8 08-26-2016 07:39 PM
Moving to Kansas Baatzy Kansas Chapter 7 05-06-2016 08:48 AM
Download/save tunes from a Hydra to local file? Sous 1999 - 2003 7.3L Power Stroke Diesel 2 01-13-2016 07:49 AM
PHP Hydra Help Tom Lyons 1999 to 2016 Super Duty 0 07-23-2015 11:01 PM
Hydra multi-position chip? SSSimon Australia Chapter 40 03-04-2015 05:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
