Sync issues
What version iPhone? Did you update it recently? Is Bluetooth activated? Old iPhones had an issue with this when using non Apple headphones on the iPhone4. I think your issue is tied in to the Bluetooth setting though as a coworker had the same issue and he had to replace the phone; defective. If you can, disable Bluetooth and see what it does.
Mine will start playing my playlist but through the speakers.Only if I shut the truck off while playing a song.If I stop the song prior to turning truck off it wont start playing automatically when I start it the next time.But it always connects to sync via bluetooth no matter what as it should.So only thing I would recommend is hitting stop on the song b4 shutting down truck and see if it doesnt play on next start up.
Just did some digging and this has been a serious issue for others on different forums. Took a TSB to get it fixed for VW. Exact same problem. There is no setting on our iPhones to stop them from auto starting when pairing with a device because it assumes you want it to play so there's a glitch in the hardware software that does this and obviously if you don't catch it, your phone battery will drain. On some radio systems (in vehicle) they have a setting that can be used to play Bluetooth music automatically. I'm being lazy and not going out to the truck to see if we have it but that would solve the problem....this affects more than just iPhones as well.
86F150-Lariet
30
07-19-2006 01:37 PM
