Value of used ZF5 and BW1356??
What's a used ZF5 and transfer case in good shape worth? I'm going to look at some parts and was thinking of grabbing them as spares.
I just got my 89 F250 in December and it won't shift into 4L. I don't know yet if it's just the linkage seized up or bigger issues. Regardless, I was going to rebuild the used transfer case while still using my truck, then swap it into my truck and keep the ZF5 as a spare.
The seller offered me a set of F250 diffs, the ZF5, and the transfer case for $500 Can/$450US. But I don't think I need the diffs.
The guy is also asking $200 for a running '79 460/C6 and $200 for a 302 dealer crate motor with 50K km/ 31K miles. Just wasn't sure on value of the ZF and BW1356. I was thinking off grabbing the 460/C6, 302 and the ZF and 1356.
Thanks.
Thanks.
This is my first diesel truck so I wasn't sure on the value of the parts.
It is an IDI diesel bolt pattern. The diffs, 1356, and ZF5 all came out of a rusted '89 F250 that popped the head gaskets. He also has an '91 F350 2wd IDI pattern ZF5 for $300. I original was going to look at a 91 F150 he has for sale with a 3" body lift and 6" suspension lift. He was asking $1500 for the truck and the 31K 302. Maybe I'll try and grab everything in a package deal seeing what the ZF5's are worth.
Thanks for the advice guys.
I wanted to build a 7.3/ZF5 2wd tow rig so that's why I wanted the 2wd ZF5.
I went and looked at all the parts and made a deal. The guy wanted the stuff gone and gave me a great deal on a bunch of stuff.
For $2000CAD/$1800US I bought:
A 1991 F150 302/5speed 4x4 Ex-cab with a one year old Rough Country 6" lift kit and 3" body lift. It has 300K km's/186K miles on it, the cab corners are shot and the wheel wells were opened up to accommodate 44's but it comes with a complete extra mint front clip, aluminum rims and decent tires.
The 31K mile 302 Ford crate motor is in a 90 F150 2wd reg cab that has no box so he threw in the whole truck. It was put in by Ford as a Ford crate 302 long block so I'm hoping it's a roller block.
The complete drive-train out of a 91 F250 (front and rear diffs, 1356, 7.3 with blown head gaskets and the 4x4 ZF5.
Miscellaneous parts include a complete rear end out of an F350, used 7.3 rad, 2wd ZF5, and possibly two 6.9's(one is seized and the other was running when stripped out of a rusted F250) but he might keep them.
I also got a 1984 T-top Trans Am that is in pretty solid shape except for the drivers side floor and dented drivers door. It has the crappy 305 but I have 75 Vette 350 and Super T10 to drop in it.
Received 3,091 Likes
on
on
buffalobob
11-20-2005 04:45 PM
