07 sel+. wrech/abs/track/ lights on thru carwash - Ford Truck Enthusiasts Forums
Crossovers Edge, Taurus X, Freestyle, MKX, Flex etc.
Old 03-28-2014, 03:53 PM
engr146's Avatar
engr146 engr146 is offline
engr146 is starting off with a positive reputation.
Anyone else had this issue,last 2 times thru my dash light came on,they did go back out and everything normal,but I am concerned about the wrench light for power train malfunction.
Old 03-28-2014, 03:58 PM
engr146's Avatar
07 edge sel +
Old 07-21-2014, 12:57 AM
Driver Jim Driver Jim is offline
Driver Jim is starting off with a positive reputation.
Easy enough. There is some exposed wiring somewhere that when wet shorts throwing false warnings. All three lights tie into ABS/Traction Control, which is Multiplexed into the PCM.
Since you didn't specify it doing it in rain, I'd assume something under the hood were water drains when the vehicle is at rest.
FYI, that little yellow wrench is Ford's cheap way of saying Seek Service Soon. It'll come on for any and everything including when service is due. It's a basic Malfunction Indicator Light and it trips when an issue in a system needs dealership attention. There should be hard, inactive codes in your PCM that will point to the ABS having a short somewhere.
Old 07-21-2014, 03:26 PM
engr146's Avatar
wrench light
Thx! Great info.would the wrench light come on @150,000 mi automatically when ford suggests trans fluid change.
Old 03-05-2015, 02:28 PM
engr146's Avatar
Was the right side speed sensor,replaced it no more track/wrench/abs lights flashing.
Quote:
72 f100 cluster lights do not work. Byronlenz 1967 - 1972 F-100 & Larger F-Series Trucks 4 09-25-2015 11:27 PM
Wiring a Rigid Lightbar - How? jwanck11 6.7L Power Stroke Diesel 7 05-17-2015 07:21 PM
cab roof running lights Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 40 03-17-2015 10:07 PM
external transmission filter is see thru speakerfritz 1999 to 2016 Super Duty 10 11-07-2014 04:50 PM
Generator light staying on 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 37 08-12-2014 11:09 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
