Oil residue in intact tract from PCV - Ford Truck Enthusiasts Forums
Old 03-28-2014, 11:17 AM
OpenTrackRacer OpenTrackRacer is offline
OpenTrackRacer is starting off with a positive reputation.
I was doing some work on my 2006 Ford F53 chassis motorhome with a 2005/2006 3 valve V10 and noticed a lot of oil residue in the intake tract just ahead of the throttle body. It's coming from the passenger side valve cover via the PCV line. My first thought was a bad PCV valve but I can't even locate it on my three valve engine.
Does anyone know where it's located or have any insight on the issue?
Thanks!
Old 03-28-2014, 05:36 PM
Gage2502's Avatar
Gage2502 Gage2502 is offline
Gage2502 is gaining momentum as a positive member of FTE.Gage2502 is gaining momentum as a positive member of FTE.
Thanks!
Well Im lost on that one too.....
I have heard that you have to replace the whole valve cover to change the PCV valve.....
But than I see that Rock Auto sells the PCV Valve for under $15
Motorcraft - Valve Assembly
Part # EV270
2.0 GDI engine issues SidecarFlip Transit Connect 24 04-17-2016 09:50 PM
Burning oil through PCV system? Pele Excursion - King of SUVs 17 06-13-2015 02:43 AM
PCV system issue OpenTrackRacer Modular V10 (6.8l) 3 06-12-2015 09:40 AM
PCV Valve in a V10? Why is it connected to coolant? Pele Excursion - King of SUVs 3 10-07-2014 09:41 PM
Oil in the air box & PCV replacment on 08 5.4 08F1Tizzy 2004 - 2008 F150 1 11-15-2012 09:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
