hi beams - Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
hi beams
Old 03-28-2014, 08:39 AM
thomasm thomasm is offline
thomasm is starting off with a positive reputation.
hi beams
hi beams on 2013 explorer seem to light up vertically rather than horizontally. It lights up the top of 70 foot trees but doesn't seem to help driving much more than low beams. Dealer says nothing is wrong but he hasn't driven it at night. Anyone else notice this. Thank you
Old 03-28-2014, 11:12 AM
Dogwood36322's Avatar
Dogwood36322 Dogwood36322 is offline
Dogwood36322 is starting off with a positive reputation.
I noticed it on my 2014 also. It is the nature of the beast I guess with the projector lights. I took mine in to dealer and they adjusted but were worse when I got it back. I made my own adjustment at night but the vertical cannot be adjusted to horizontal as far as I can tell, I could not find a lateral adjustment screw anywhere.
Old 03-31-2014, 03:02 PM
Chinookman's Avatar
Chinookman Chinookman is offline
Chinookman is starting off with a positive reputation.
My 2003 F-250 and 2010 F-150 Lariat does the same thing...it would seem FORD should work on a better high beam system. I have to rely on my driving lamps on my 250 and am SOL on the 150 ....
Old 04-01-2014, 07:19 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
Honestly I've rarely looked at either of our 2013's...
but park about 10' away from your closed garage doors (or pointed at a blank wall) at night and take a picture of the beam pattern..
let's see what we see
Most vehicles I've had had some odd beam pattern with the exception of the wife's 2011 Audi Xenon's and it had a top cutoff like it was done by a razor knife !
Old 04-02-2014, 06:43 PM
PupnDuck PupnDuck is offline
PupnDuck is gaining momentum as a positive member of FTE.PupnDuck is gaining momentum as a positive member of FTE.
Here's a link to the Ford video on how to adjust the headlamps:
http://www.fordservicecontent.com/Fo...adlampAdj2.wmv
Since they only use a single filament bulb along with a mechanical shutter assembly in the headlamp to provide low / high beams the amount of adjustability is limited.
Voltage at hi and low beam bulbs lowlander 2015+ F150 6 09-21-2016 09:18 PM
hi beam dash light won't stay on, any clues? Bluey Zedoff Electrical Systems/Wiring 3 07-25-2015 02:40 AM
High Beam lights don't work BombThreat 1968-2013 Full Size Vans 2 11-12-2013 10:47 AM
No lo beam headlights sflem849 1999 - 2003 7.3L Power Stroke Diesel 9 08-07-2012 08:23 AM
99 Expy headlight high beams not working popeye47 1997-2006 Expedition & Navigator 5 07-31-2012 08:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
