took a break from my truck (bike question) - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 03-28-2014, 12:59 AM
cyclospot cyclospot is offline
cyclospot is starting off with a positive reputation.
My 2000 Buell. The oil light flashes on when I downshift for a milisecond. I'll put a gauge on it to check just thought I would get some thoughts on why. Maybe a sticking oil pressure regulator?? 16000 miles revtech oil and filter about 1500 on current oil. Pushed some oil out the tank at startup but I may have overfilled it last year while it was cold. I drained a half a quart out and seems fine now. The first time I noticed the light was on the interstate at downshifting at 70 mph. It did it driving a block today and could repeat it at 20 mph. Know its not a Ford..... searched the buell forums but thought I would get some expert advice! Thanks
Old 03-28-2014, 10:11 AM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
Treat is as a Sportster for troubleshooting purposes. Also, ALWAYS post the SPECIFIC model and not just brand. You wouldn't post "I have a broke Ford" with no other info.
I'd suspect a loose connection, and after that the sending unit which are cheap to replace.
You can use a mechanical oil pressure guage plumbed to the sender fitting, and even use a tee to feed both if you wish.
There are two things to own if you have a motorcycle, particularly anything HD based. The FACTORY service manual and parts book will save you much suffering. Haynes and Chilton manuals are fine if you run out of cat litter and need to sop up an oil spill.
Forums I've found useful:
Harley Davidson Forum: Harley Davidson Motorcycle Forums
Chop Cult - bobber, chopper, choppers, harley, harley davidson, harley davidson motorcycles, harley motorcycles, harley sportster, kawasaki motorcycles, motorcycle accessories, motorcycle helmets, motorcycle parts, motorcycles for sale, suzuki motorc
HarleyTechTalk - Index
Let us know what you find.
Motorcycle Chatter oddfordjunkie Washington Chapter 185 09-10-2016 01:30 PM
blow by? rings? buell.rider Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 09-01-2011 07:07 PM
Breather Cap Oil Leak buell.rider Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 04-04-2011 10:39 PM
air horn pics!! Gobstopper909 1994.5 - 1997 7.3L Power Stroke Diesel 18 10-24-2008 08:35 AM
Anyone here have a Buell? PowerstrokeJunkie General Automotive Discussion 25 06-08-2008 03:49 PM
Tags
buell, harley, motorcycle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
