Head Bolt/Stud Tech thread...
Ok ARP 7.3 Stud detail time....
These are the 8740 190Kpsi bulk studs that you get through Typ4 or R&D....
7.000" @0ft/lbs
7.014" @90ft/lbs
7.015" @100ft/lbs
7.017" @110ft/lbs
7.019" @120ft/lbs
7.020" @130ft/lbs
7.022" @140ft/lbs
7.023" @150ft/lbs
Check- No stretch- 7.000" @0ft/lbs
7.023" @150ft/lbs
7.023" @160ft/lbs
7.026" @170ft/lbs
7.028" @180ft/lbs
Check- .005" stretch- 7.005" @0ft/lbs
7.028" @180ft/lbs
7.031" @190ft/lbs
7.038" @200ft/lbs
Got 1 click at 210ft/lbs of torque, and then it just kept turning...
By these results, I would say that its plenty safe to go to 160ft/lbs without stretching the stud, and probably up to 180ft/lbs if you really wanted to chance it.
I wanted to test the 7.3 head bolt tonight, but just didn't feel like it, so Ill do that tomorrow along with the 9/16" head stud.
7.000" @0ft/lbs
7.014" @90ft/lbs
7.015" @100ft/lbs
7.017" @110ft/lbs
7.019" @120ft/lbs
7.020" @130ft/lbs
7.022" @140ft/lbs
7.023" @150ft/lbs
7.023" @150ft/lbs
7.023" @160ft/lbs
7.026" @170ft/lbs
7.028" @180ft/lbs
7.028" @180ft/lbs
7.031" @190ft/lbs
7.038" @200ft/lbs
Ok Stock 7.3 Head bolt detail... And actually surprising.... To me anyway...
6.425" @0ft/lbs
6.441" @65ft/lbs
6.446" @85ft/lbs
6.448" @105ft/lbs
6.451" @110ft/lbs..... Spec
6.453" @120ft/lbs
Check- .005" stretch- 6.430" @0ft/lbs
6.453" @120ft/lbs
6.460" @130ft/lbs
6.465" @140ft/lbs
Check- .020" stretch- 6.445" @0ft/lbs
6.470" @140ft/lbs..... .005" stretch from last 140ft/lb measurement...
150ft/lbs clicked after 1 full turn...
Broke the bolt at 160ft/lbs....
Bottom line, I wouldn't trust the 7.3 bolts past spec, its just too unpredictable, even if I tested a weak bolt. Based off of this bolt, the stock bolts are pretty much TTY units, even if they aren't officially that way from the factory....
I will probably test another one just verify the results, but im pretty sure this is the way it is....
9/16" stud next...
6.425" @0ft/lbs
6.441" @65ft/lbs
6.446" @85ft/lbs
6.448" @105ft/lbs
6.453" @120ft/lbs
6.453" @120ft/lbs
6.460" @130ft/lbs
6.465" @140ft/lbs
9/16" stud next...
This really makes me think I want to go with the 9/16" studs if they show better than the 1/2". What would have to be done to make this work on a 7.3 in your opinion? Would the 7.3 have to be drilled at 6.9 depth? And with that depth do you think that there would be issues with thread interference or anything?
Humm.... I thought that 7.3NA was 100 spec and 7.3 turbo was 110 spec and the bolts are the same. Just added torque for the turbo pressure.... I went to 115 on my stock bolts. I think I'm good at that... for 18psi into a decompressed J2 cam Engine at 90cc's .... My next build will get studs for sure...
#28
Arp head bolt
Hi,
I'm new please forgive!
First diesel, second post on site.
I'm new to diesels and been reading a lot of info from this site. THANK YOU!
I need to replace the coolant and I believe the head gasket might be leaking.
Obviously from the above posts, ARP are the best. Where do I get these from and what size? I have not taken anything apart yet.
What head gaskets do you recommend? And where to buy?
I got the thermostat information from the "6.9l diesel tech info page" but I guess I missed the gasket and head bolts info.
Additionally any info regarding doing this job will be much appreciated.
Thank you!!
Thank you!!
#29
#30
Hi,
Thank you!!
Thank you!!
