6.4L Hose Coming through Radiator Fan Shroud??
Just picked up my truck from the dealer after a trans flush. While it was there I had them replace both windshield wiper nozzles. They called and told me the hoses needed to be replaced as well--- OKAY fine do it.
Come home and decided to "make sure" the trans fluid was at the correct level.
Open the hood to discover a loose black hose approximately 1/4" or so in diameter coming out of the radiator shroud directly at center of the top. The end of the hose was somewhat towards the passenger side battery.
I figured okay the tech probably just left my old windshield wiper hose on top of the motor and forgot to discard it...
I follow the hose and it appears to go in between the rubber seal for the shroud and the plastic housing. I looked back behind the fan and can see the hose twirled around an aluminum or stainless steel pipe coming up just in front of the fan but behind the numerous condensers...
MY question is two fold:
should this hose be here, or is it indeed the wiper hose that got sucked into the fan?
if it is supposed to be here, what does the end that was leaning towards the passenger battery connect to? it certainly appears to have been previously connected to something whether the washer or some other barbed fitting....
all help greatly appreciated!
carprojects
05-04-2010 10:17 PM
TexasGuy001
02-16-2006 09:14 PM
