1994 MAF Upgrade
https://www.ford-trucks.com/forums/a...1&d=1396051227
These are the same as the pin-outs in my manuals. If you go down the lists you'll see many differences. Don't get me wrong, not overwhelmed about this, just wanted to make sure before I start that my assumption is correct. The new computer will be the FLY1 we spoke of yesterday mot likely. Thanks again guys.
Also, be careful when removing the pins from the connector. The plastic can get brittle and the clips on the inside of the connector can be fragile. If you break one of those clips then the wire you insert in that hole won't stay put. Replacements can be bought if needed.
A screwdriver will work to remove the pins but I have had better luck with a tool like this that has a slight angle - http://www.imgur.com/2JQfOPj.jpeg
Paul, I have another semi related question, sorry, but I think part of what's got me chasing my tail (in my mind) is that this is a 94 truck e4od and doing the MAF and computer from a 95 I'm gonna have to deal with the change in the tranny solenoid pack, correct. That's probably why the wiring diagram is different.
Jason185512
18
02-08-2017 05:09 PM
f150truckguy
05-29-2014 12:27 AM
darthice
12-23-2009 05:00 PM
