C4 Reverse Servo Seal replacement - Ford Truck Enthusiasts Forums
Old 03-27-2014, 02:31 PM
NW1980F150's Avatar
NW1980F150 NW1980F150 is offline
NW1980F150 is starting off with a positive reputation.
A little help please.
Started my 80 F150 this morning and put her in reverse and heard a loud hissing. So I looked under and seen trans fluid all over the drivers side and floor. Got under to see where and I seen two of the bottom bolts on the reverse servo cover where not tight and looks like part of the gasket is sticking out.
Tighten the bolts and started the truck and same thing happened.
So how hard is it to replace the seal ?
Thanks for any info.
Old 03-27-2014, 03:45 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
You will probably have to go to a tranny shop to get the gasket, so ask them while you are there. That's what I did when I had the governor gear strip on a turbo 350. I had to go to the tranny shop to get a new one, they had it on the shelf. And had a nice little talk with them while I was there.
2006 f150 low/reverse servo MudMik 2004 - 2008 F150 1 03-21-2015 12:14 AM
Cruise Control Update...Question Matt M, PA Excursion - King of SUVs 0 08-05-2014 11:35 PM
2005 ford expedition trans problems d_leib Expedition & Navigator 0 05-23-2014 10:49 PM
cruise control servo interchange question Seitz372 1987 - 1996 F150 & Larger F-Series Trucks 1 03-30-2013 11:26 PM
2004 F-150 OD repair and valve body modification (J-mod) 96_F250_Deezal Clutch, Transmission, Differential, Axle & Transfer Case 2 12-17-2012 11:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
