Removing ac pulley 95 f150
Old 03-27-2014, 12:45 PM
fordka's Avatar
fordka
fordka is offline
Ok yesterday i started my truck up and the ac pulley seized. I had it running a just an hr before that so it seems strange that it would seize. So anyway i want to run a shorter belt but i cant because it will rub on the pully and make grooves in the belt. I have gone through that once all ready. So i was just gonna take the pump off completely but i cant get any bolts out. So now i decided just to take the pully off. I got that triangle piece off in front but i cant get the pully off. Ive pried on it and bent it up pretty good tho. So does anybody know. If not i will torch it off. Thanks
Old 03-27-2014, 01:07 PM
danr1's Avatar
danr1
danr1 is offline
Sounds like you don't have a three jaw puller or you'd already used it to pull the pulley off the shaft.
Need a puller for the pulley the clutch itself no.
1996 Bronco/F-Series Workshop Manual
Was hoping the link would be direct but no such luck.
You'd find it under climate control system then ac compressor.
Old 03-27-2014, 01:11 PM
fordka's Avatar
fordka
fordka is offline
I have one but theres no way i would beable to get that to fit in there with the radiator.
Old 03-27-2014, 01:20 PM
danr1's Avatar
danr1
danr1 is offline
Yea problem too, use torch to blow bolt heads off then pry compressor off them then remove what's left of bolts, A/C eliminator bracket with idler available from Napa retains use of stock belt (IIRC was about 40 bucks), if wanted to go that route.
Old 03-27-2014, 01:37 PM
fordka's Avatar
fordka
fordka is offline
Haha i got it just needed a bigger pry bar lol then i had an explosion of whats left to the bearings. So im betting thats what caused it to seize so my pump is prolly still good. I hope a belt is not $40 i bought a new belt off ebay for $12 for my ac set up look 3 months ago.
Old 03-27-2014, 03:04 PM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
The AC delete bracket and pulley is $40, not the belt.
Seems as though you're done now, but for anyone in the future that's looking to do this without being a complete hack and destroying things....
Remove the bolt in the center of the clutch, then the clutch plate (triangle thing) comes off. After that, remove the snap ring in the center of the pulley, and slide the pulley off.
Old 03-27-2014, 04:13 PM
fordka's Avatar
fordka
fordka is offline
Im only a hack because this truck is hardly worth the gas i put in it. If this truck really meant something to me sure i would take my time and do it the right way. But its just an old beater. And my bad thinking the belt was $40 lol but still there expensive through stores according to my dad but he hasn't bought one in a while.
Old 03-27-2014, 09:31 PM
MeanGreen460's Avatar
MeanGreen460
MeanGreen460 is offline
They make a special puller to take the AC clutch and pulley off you can rent one from most auto parts stores
Old 03-28-2014, 07:32 AM
Bob Gervais
They do rent pullers, I've never needed one. I've done at least, if not more than 50 clutches/pulleys, they all slid off.
stronger66ratfink
04-05-2016 05:48 PM
jonnygorgo
02-14-2014 07:38 AM
Whitey Ford
12-30-2013 07:47 PM
airmark
1999 to 2016 Super Duty
06-20-2012 05:18 PM
childsplay
01-07-2006 06:49 PM
Quick Reply: Removing ac pulley 95 f150
