May have found a donor truck..
Well my donor truck fell through. Main goal was PS and it didn't have it, the kid thought it did, but he was wrong. The truck was his dad's and has been parked for several years.
So back out looking again, looking for PS and PB, would like to pull everything from the steering column, PS Gearbox, out to and including the Disc brake spindles, as well as the PB booster.
I know I can look at 73 to 79 F100's but can some one give me a quick list of what other years / models will work? Such as the F250 or Broncos, will those work, if so what years?
Thanks very much,
Thanks very much,
on
Just for the heck of it google "electric steering assist". I read somewhere I think in classic trucks about an electric motor assisted steering setup for our old trucks. The motor went on the column under the dash. This would save you from finding the pulleys, pump, steering column and a bunch of other stuff needed to for hydraulic power steering to your Ford. I remember thinking that this might be a good idea to try someday.
If your 1966 is 2WD w/a 240/300 I-6: 1973/79 F100 2WD & 1975/79 F150 2WD. 240 cancelled at the end of the 1974 model run.
F250 is different as is Bronco, as all Bronco's are 4WD's.
I already have those. The PO had a 351W in it, but it was bored .060 and was making all sorts of noise. I've bounced back and forth on going back with a 351W or a 390 but have decided on a 351W.
I'm just trying to find what list of trucks can I look for to get the PS, PB, and linkage from.
1965/77 P/S pump has a steel reservoir, P/S pressure hose threads on.
So, if someone has a 1965/76 with an FE engine, will require the steel reservoir pump and brackets, because the FE P/S pump mounting brackets will not fit the plastic reservoir pump.
1981: First year 351W installed in F150/350 & Bronco. 1980 and later engine mounting parts will not work on 1965/79's.
If the OP wants to swap a 351W engine, will need 1969/79 F100 302 or 1975/79 F100/150 302 engine supports aka perches/towers/stands.
These supports are also the same as 1977/79 F100/350 351M/400 2WD
Ford changed the P/S pump in 1978 for cars, Bronco's and F100/350's, it's smaller in diameter and has a plastic reservoir. P/S pressure hose attaches to pump w/a qwik connect fitting.
So what years, what trucks can I get the following list from, that will bolt onto my 66 F100
PS Gearbox
PS Linkage
PS Steering column
Spindles
PB Booster bracket
BP Booster
Sorry, but this is all I'm asking, what year of trucks can I get this list of parts from?
such as
F100 73-79
F 150 ??
F 250 ??
Bronco ??
So what models / years can I find these parts on. Yes I'm trying to find a donor truck, but I'm trying to find the list of trucks that will work first.
