Removing step side bolts from side panels
Old 03-27-2014, 10:17 AM
bcamill's Avatar
bcamill
bcamill is offline
I have ordered new stainless steel bolts to hold on my fiberglass fenders on my 83 step side, but I am having trouble removing the factory bolts. Any suggestions?
Old 03-27-2014, 10:22 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Welcome to FTE
Maybe this pic will help. Body style 83 is a Flareside pickup. A step side is a Chevrolet.
Old 03-27-2014, 10:27 AM
reamer's Avatar
reamer
reamer is offline
The original bolts "bite" into the sheet metal. To get the fiberglass fenders off, set your ratchet to tighten them and snap them off.
Then get a socket with the opening BIGGER than the heads on the inside, put the socket over the head and slam them out from the other side.
I'm doing this right now to on my 84 Flareside.
Or if you have a blue-wrench heat the steel, and the bolts "pop" out with a light tap.
Old 03-27-2014, 10:29 AM
bcamill's Avatar
bcamill
bcamill is offline
Thank ou. This makes sense.
Amphihauler
11-05-2017 05:43 PM
Indybeer
19
09-23-2016 11:15 AM
g84t8f1
03-11-2009 01:18 PM
skymonkey
10-06-2008 09:04 PM
55forder
02-24-2006 10:26 PM
Quick Reply: Removing step side bolts from side panels
