Flex plate replacement
I've called a couple shops to get quotes to have my flex plate changed. One shop said they would have to lower the engine a few inches to get the tranny out easier. From what I can see this is not needed. Anyone with experience on this know if dropping the engine is needed? Thanks.
Yes you can , with enough extensions , and flex joints, I'm sure you can do it , let us know how that goes , OR you could take off the crossmember , and when it naturally tilts down a little , you can take it off , I'm sorry , but why ask a question, then 2nd guess the person ? (just wondering )
In cases like this youtube is your friend just search for a video on removing a transmission from a ford pickup,..
The quicker way is not always the smartest way. Don't forget, as you add extensions and universal joints you reduce the amount of torque being transferred from the ratchet to the bolt. This will make it harder to loosen the bolt. Also, you are increasing the chances of the socket twisting and slipping off the bolt and rounding it off. Good luck getting it out then.
Well I'm stuck. My truck is supercharhed and in order to drop the engine enough, it looks like I need to remove the supercharger because it is hitting the firewall. I called the stealership and the said they would lift the cab!! I guess my question is, is the metal gasket between the supercharger and intake reusable? And if anyone has a better idea let me know! Thanks again.
I am not familiar with the super charger gasket replacement, if it was me I never reuse. I find the extra few $ gives me piece if mind.
As far as lifting the cab, that is a fairly common practice now. I have seen many trucks that need this for different repairs. The cab doesn't need to be removed,just tilted. You loosen the body mount bolts and Jack the body up enough to give you room
Good luck
Good luck
