Should an SROD 4x4 tranny be on the "to hunt for" list?
Old 03-26-2014, 11:17 AM
reamer's Avatar
reamer
reamer is offline
In the on going quest to get overdrive into a 1983 F-150 4x4, the "holy grail" seems to be the small block ZF 5-sp.
I'm probably going to stick with rebuilding the NP 435 I have.
But with the ZF comes costly front and rear driveshaft re-building, along with Cab floor "modification" and shifter relocation.
No much has been said about the 4x4 style SROD (4speed OD mostly from broncos).
are these as good as ZF's? or are they in the class of the M5OD and not worth the hassle?
Old 03-26-2014, 12:44 PM
1984F150Guy's Avatar
1984F150Guy
1984F150Guy is offline
subscribed. I'm curious about this too.
Old 03-26-2014, 12:49 PM
reamer's Avatar
reamer
reamer is offline
Be interesting, Looks like the SROD has no "granny" first.
The NP 435's second gear is the SROD's 1st. and with that you get room for an OD.
Old 03-26-2014, 01:18 PM
Ken Blythen's Avatar
Ken Blythen
Ken Blythen is offline
The SROD is light-duty (the lightest of the three OD transmissions of it's era); it also has bad ratio spacings......worse than the NP435
Old 03-26-2014, 01:37 PM
reamer's Avatar
reamer
reamer is offline
Welllllll, there you go.........
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
There are several variations on the SROD. Most are aluminum cased. Shifter parts for the side shifted iron model are hard/impossible to find. No granny, big gap 2nd to 3rd.
IMO not worthy of a swap in.
What axle ratios and tire are you running?
Old 03-26-2014, 03:08 PM
reamer's Avatar
reamer
reamer is offline
3:50 31" tries
Old 03-26-2014, 03:50 PM
85e150's Avatar
85e150
I had the iron 4 speed OD, 3.50s and 31s in an E150 van. Pretty doggy compared to the stock tires.
If you are mostly local and offroad, rebuild the NP435 IMO.
Old 03-26-2014, 04:09 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Reamer - I disagree on two points:
  1. Driveshaft: I took an NP435/NP208 combo out, installed a ZF5/NP208, and bolted the same driveshafts back in.
  2. Floor: I took the original tranny cover off and installed the tranny cover that was used with a ZF5. No problems whatsoever and it is a perfect bolt-in.
Edit: As I think I've said before, I paid $500 for my ZF5 and am facing a $650 rebuild. Were I to do it over again I'd buy a rebuilt unit with a warranty.
Old 03-26-2014, 04:30 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,680 Likes on 1,357 Posts
If you are going to use this truck as a daily driver, the M5OD is not that bad of a tranny. It's just not as heavy duty as the zf. Most all later f150's came with the M5OD if they were a manual truck.
Old 03-26-2014, 04:45 PM
reamer's Avatar
reamer
reamer is offline
Isn't the @ZF 2" longer than NP435?
I would shorten the rear and lengthen the front the 2" to put the splines back to proper depth... But that may be just me.
Old 03-26-2014, 04:48 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
I have 5000 miles on mine with nary an issue. The mount for the ZF is ~1" further toward the rear, but I don't think the transfer case was moved at all. The drive shafts bolted up perfectly.
Old 03-26-2014, 04:54 PM
reamer's Avatar
reamer
reamer is offline
OK, you win
Old 03-26-2014, 05:38 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
If you need me to I can measure the ZF and NP tomorrow.
Old 03-26-2014, 06:06 PM
reamer's Avatar
reamer
reamer is offline
Don't need you to, but I'll feel better knowing I made you crawl under and measure for the fun of it!
Quick Reply: Should an SROD 4x4 tranny be on the "to hunt for" list?
