Power steering pump
How many miles in that month? Note in box states can take 500 mile break in.
Want a better pump yea not a bad thing, run large tires yea gonna need one but a unnecessary expense if run stock tires and its a road runner. If so give it a little time to fully break in and make sure you purged it well you know turn and hold briefly at full lock both directions couple three times.
And yea if you ran anything but type F trans fluid it will squeal, for silent operation must be 100% type F nothing added in with it.
You probably still have air in your p/s system .the correct way to bleed these is jack up front of truck so wheels are off the ground first with engine off crank steering wheel all the way right hold it for 5 to 10 seconds then turn it all the way left hold again 5 to 10 seconds repeat this several times if p/s fluid is foamy it has air in it .you will puke out some fluid doing this just keep adding then start engine and repeat the same process turning lock to lock and holding .by doing this you should get most of the air out and your pump should be much quieter .Use type F atf fluid
I am almost certain the issue is not in fluid or air in the system. Ford put a junk power steering pump in these trucks. It is even worse when you have larger tires. When my truck had 35's on it it burned up 4 genuine Ford pumps in 30k miles. They were not rebuilds either but rather brand new pumps.
Do what you want to do .I'd recommend bleeding P/s pump as I told you .I worked 20 yrs at a Ford truck Dealership and have been driving ford Trucks for 40 plus yrs and I have never replaced a P/S PUMP on my own Trucks but have done a lot of them when I worked at the Dealership .
