Can HEC be programmed out? - Ford Truck Enthusiasts Forums
Computer Chips & Tuners SPONSORED BY:
Old 03-26-2014, 12:26 AM
cptn60 cptn60 is offline
cptn60 is starting off with a positive reputation.
Ok, I did try a number of different searches on here with no real answers. Here's where I am. Got a free 4.6/4r70w out of a 99 CV, along with a PCM and wiring from a 2000 GrMqs. Friend is mechanic at a local cab co, and they just updated their fleet. Plan is to locate a 53-56 F100 and swap it into that. Since there is precious little extra room, I really don't want to piggyback 2 systems if I can get around it. I want to delete PATS, EGR, and the HEC(cluster). I'm very new to the Injected world, built a lot of carbureted vehicles over the last 35 years though. So send it off to reflash, or buy a programmer? Or is it even a big deal?
Old 03-28-2014, 11:14 PM
For anyone interested; got an evtm for the 2k cv, turns out the pats is in the cluster. If you shut pats off; no cluster to contend with.
Old 03-31-2014, 05:57 PM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
Good to know. Thanks for posting.
2002 F350 Truck won't crank- SOLVED ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 6 10-27-2016 08:46 AM
Fuel Tank and Shield Brother Hec General Diesel Discussion 1 05-05-2016 12:51 PM
Gas Tank Replacement Brother Hec 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-11-2016 02:12 PM
Intrument cluster, circuit board replacement hachedete 1997 - 2003 F150 7 03-18-2011 07:25 PM
Changing Odometer from Miles to Kilometers Abbie 2004 - 2008 F150 2 11-11-2007 12:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
