03 EXPLORER EDDIBAUER 4.6 AWD CANT FIND TRANSFER CASE MOTOR ANYWHERE
Hi all Im having a hard time finding any supplier that has the correct motor for my transfer case. The one they keep sending me has on one connector and the one one mines has 3 connectors... Anyone have this problem before?
Thank you Laki
Thank you Laki
Theres and 4wd and 4 high and 4 low. yes theres a motor and the one on mines has 15 pins that are all used and the ones Ive been ordering and getting only have 8 of the pins used. im trying to find the connector that has all pins used like on mines. thank you
You must have one of the IVD equiped models. It's also called Advance Trac. According to the 2003 wiring diagram the IVD and non-IVD models use the same single 16 pin connector. You have 3 individual connectors on a pigtail(s) coming off the shift motor? Sorry, I'm no help... Good luck, hope someone can help.
Then you dont have AWD, that is your problem. You have AUTO4x4 which is a completely different system.
Motor Part Number
If you will do this I will send you the part number you need! I think I can get it just with the Vin. number.
The other wires in the connector are for the speed sensor and the magnetic clutch. You pull each wire out of the original connector and insert it into the new connector. Do one at a time so you don't mix any up. To remove the wires you have to pull out the red lock in the connector and use a pick to release the locking tab for each wire. Be careful not to break any of the tabs or the wire may come out of the connector anytime.
Straight from A-1 Cardone page.
NOTE FOR FORD VEHICLES:
The motor may still be tethered to
the vehicle by speed sensor wires.
These wires must be carefully
transferred to the replacement
motor connector as described
below (refer to a service manual
for detailed procedures).
• First remove red locking tab.
Carefully record wire pin
positions.
• Using a suitable tool, release
each wire pin.
• Install wire pins in the
replacement motor connector
exactly as in the original motor
connector until they snap in
place.
• Verify pin placement.
• Replace red locking tab. This
completes wire pin transfer.
5. Note position of transfer case
shaft.
positions.
each wire pin.
place.
shaft.
Arizona97
03-18-2017 06:37 PM
NFG(New Ford Guy)
11-09-2003 11:32 PM
dinograd
01-18-2002 08:01 PM
