66 F100 C-Bushings
66 F100 C-Bushings
I'm looking at replacing all the bushings on my 66, but when i'm looking at the front suspension C-Bushings, they come in different degree's of "Offset". What is this offset and any idea of what offset I need? My truck is stock, as far as the frame, 2wd. However I do plan at some point doing the disc brake conversion.
Sorry, I may have been looking at the wrong picture when trying to find what all bushings I would need to order.
I think those may be for 4WD not 2WD not sure, but they are the control arm bushings. The image I was looking at just had them listed at C-Bushings.
Client Validation
Client Validation
Left: 1965/69 F100/250 2WD / Right: 1966/72 F100 4WD ~ 3B203 = Radius Arm (aka C) bushing.
3B203 radius arm bushings also used on 2WD's, but they're round, not C shaped.
There are no control arms on any 1961/66. "C" bushings (sorta resemble the letter C) are radius arm bushings that were only used on 1966/79 F100 4WD's that came with coil spring front suspension.
There are no control arms on any 1961/66. "C" bushings (sorta resemble the letter C) are radius arm bushings that were only used on 1966/76 F100 4WD's that came with coil spring front suspension.
I knew you were right Bill, but my my brain ignored F100!
68shortbedmo
08-11-2012 10:12 AM
