3rd rear shock? - Ford Truck Enthusiasts Forums
2011 & Newer Explorer Discuss the all new redesigned Ford Explorer
3rd rear shock?
Old 03-25-2014, 10:50 AM
helirich helirich is offline
helirich is starting off with a positive reputation.
3rd rear shock?
I saw a third shock on the rear of a explorer. It is sideways. Does anyone know what it's for? Sway, axle rap, torque steer?
Old 03-25-2014, 02:32 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
That is on a much older Explorer with a live axle. Later models have IRS and do not have that shock. It is an "axle damper" designed to limit lateral axle movement. Some report no difference without it, some claim improved results after installing a new one.
Old 03-28-2014, 10:14 AM
Dogwood36322's Avatar
Dogwood36322 Dogwood36322 is offline
Dogwood36322 is starting off with a positive reputation.
That picture is not a live axle.
Old 03-29-2014, 12:10 AM
Looks like one to me, hung on leaf springs.
It is not IRS, it has a center diff section that looks like a Ford 8.8, an axle tube clamped to a leaf spring.....what do you think it is if it isn't a live axle?
Old 03-31-2014, 08:18 PM
It's a live axle. I still don't see what it does. How does the axle move lateral on leafs?
Old 03-31-2014, 09:10 PM
Lots of ability to move laterally on leaf springs. Some rubber bushings here, a little flex there, you can get plenty of movement. Has to be that way, otherwise you'd be breaking things all the time.
Old 04-02-2014, 05:27 PM
PupnDuck PupnDuck is offline
PupnDuck is gaining momentum as a positive member of FTE.PupnDuck is gaining momentum as a positive member of FTE.
Quote:
Shocks don't "limit" the movement of anything. If they did your ride wouldn't ride so well and you'd be replacing a lot of broken shocks. They absorb energy and convert it to heat and in so doing they "damp" motion.
Old 04-02-2014, 11:31 PM
Shocks limit suspension travel in many vehicles. The limit of full shock extension is the limit of suspension travel. I found this out with our '66 wagon when the coil spring conked me in the head after I removed a shock.
As for the lateral movement, the shock is a damper, limiting oscillation. Regular shocks do the same thing, in the manner you describe.
Shock absorber Powerstoke73 1999 - 2003 7.3L Power Stroke Diesel 3 08-03-2014 08:23 PM
Bilstein rear shock report ATP Pilot 6.2L V8 13 04-13-2014 07:20 PM
Rear shock missing a bolt aero993 Excursion - King of SUVs 3 03-18-2010 03:58 PM
Rear shock squeak goatdriver 2004 - 2008 F150 4 06-03-2007 07:47 PM
1993 Bronco dual rear shocks jerseydevil 1978 - 1996 Big Bronco 7 07-08-2005 11:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
